Car is not a chore to drive anymore
Old Jan 18, 2011 | 01:59 PM
  #31
AARONHL's Avatar
Originally Posted by Mustang5L5
I'm convinced now i need to do the fronts. Since it's 8 degrees out..i'll wait til spring. Still i want to get parts ready.
Few questions. WHo makes the OEM Nissan bearing? All i find are Timkin, and OEM nissan. Makes me think Timkin might make the OEM bearings for Nissan. Does anyone have an OEM bearing around? Any manufacturer stamp on it? There is a big price difference, so i don't want to spend $50-80 more for OEM to find it's a Timkin in a Nissan box.
Secondly...bearings are not side specific right? But they are Front and rear specific on an AWD right?
WHat about hubs? Can a front AWD hub work on the rear?
I was thinking of changing all 4 since the bearings are ~$60 each, but my press is 25 miles away at work. So after removing each bearing, id have to drive 50 miles to press in/out the hubs. Was thinking of buying a front hub/bearing assembly, installing that, and then buying just bearings only and pressing the hub out from the first bearing and using it on the other side and then continuing on to the rWould save me time. But if the front hubs can't be used on the rear, then my plan wont work.
Not sure if Timkin manufactures for Nissan, I have seen Timkin all over the place though.
Good question, pretty sure they are different (at least on the RWD) because an axle goes directly through the bearing.
Old Jan 18, 2011 | 02:01 PM
  #32
AARONHL's Avatar
Originally Posted by notorious_g35
Thank you for posting this - good to know.
It's how I diagnosed the two rear bearings within a year of each other. I should have replaced both at the same time.
Old Jan 18, 2011 | 07:12 PM
  #33
Mustang5L5's Avatar
Yes, the rwd ones are def different. But on awd, the pictures look the same because there is an axle at all 4 wheels.
Need to correct my earlier statement. Only front bearings I can find are oem for $160 each!!!
Rear bearings are Timkin for $60 each.
Would be nice if Timkin offered the fronts for sale...for $60 too. Then I can do all 4 bearings for $240....instead of $440
Because of that, I'll buy bearings only and just reuse the hubs. I have a friend that loves near my work, so I can do it there and then go use my press
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
slider_ua
Jul 29, 2015 04:17 PM
Karnicle
Jul 23, 2015 05:08 AM
