CC Not Working Help!!!!!! Video Inside!!!!!!
Old Jan 12, 2011 | 03:04 PM
kyemaul's Avatar
Whats going on fellas, Listen my CC is not working properly it is flashing set on and off....I just did a 3.54 FD upgrade, Buyt it was working fine up until now i have about 300 miles on it allready first problem. If i turn the car off and on nothing changes. !!!! All help is appriecated
Old Jan 12, 2011 | 03:05 PM
kyemaul's Avatar
Im really wondering whats going on. It set before and it set on the highway I just forgot to turn it off then i realized later that is flashing set.!!!!! And i just added my Tranny cooler B&M a couple hrs ago!!!! I hope its not that..
Old Jan 12, 2011 | 03:06 PM
The Stimulation's Avatar
Damn that sucks. I have that problem every now and then, but after I shut off the vehicle and try it out again it works just fine.
Old Jan 12, 2011 | 03:35 PM
kyemaul's Avatar
This Video is to show the cuirse control set light flashing!!!!!!!!!!
Old Jan 12, 2011 | 05:29 PM
DaveB's Avatar
I can't see videos when at work. What MPH are you trying to set the cruise at? I have an early 03 sedan with the 3.54 gear set and have no problems setting the CC at speeds below 78mph. I've never tried any higher. Your report of a flakey CC with 3.54+ gears is not uncommon. Others have reported similiar problems in the past when trying to engage CC at speeds above 72mph.
Don't you have an aftermarket higher stall TC? Here's what I think may be the problem and it may be related to the cooler. When trying to set the CC, are you certain the transmission fluid is completely warm? Cold weather, teamed with a aftermarket higher capacity cooler may not be allowing the fluid to fully warm up unless you drive for an extended period (20 minutes). I've noticed in sub 40 degree weather that my 5AT will not achieve full TC lockup until I've been driving for nearly 10 minutes, most of which is highway. It will do partial lockup, but not 100% lockup at cruise. Since you have a higher stall TC, there is more TC slippage at cruise and possibly higher cruise rpms under load and without TC lockup. The additional cooler may be keeping the fluid from reaching operational temp which is when the 5AT will achieve full lockup.
In layman's terms:
Fluid does not fully warm therefore full lockup is not achived -> Unlocked higher stall TC has slightly higher cruise rpms under load -> Deeper set gear results in higher cruise rpms -> Elevated cruise rpms and unlocked TC results in rpm cruise range that is out of spec with what the ECU expects to see with a OEM TC and 3.3 gear and/or thinks you trying to set the CC 89mph+.
My recommendation is to reset the ECU (to clear CC problem), drive around for 30 minutes to adquately warm the fluid, get on the highway, verify the TC is locking up at a steady cruise at 70mph, and attempt to set the CC.
Old Jan 12, 2011 | 07:44 PM
kyemaul's Avatar
Angry
In layman's terms:
Thanks for your advice daveb but.. I was driving for more than a hr traveling for about 40 miles. (highway miles) tranny was allready warmed up. Let me explain deeper. I was driving on the highway about 85mph i started to approach a police officer, My exhuast in 3inches custom with hfc one vibrant performance resenator so its really loud. So i decided to slow down and cc 50mph to not past the police officer. The cc engaged and proceeded to work. The officer exited the highway and i started to re-increase my speed. I forgot to dis-engage the cc so i was driving with it set at 50mph but i was on the gas pedal doing 85mph and higher. when I got off the highway 30 to 45min later i was parking and i looked down and saw that the "SET" button was flashing non stop. When i pressed cancel on my steering wheel and nothing happened. I turned off the cc and turned it back on and again.... same issue (flashing set light) !!. I then turned the car off the back on and still same flashing, I then drove the car around the area and i couldnt engage my cc at any speed neither 10 20 40 or 50mph nothing.
Old Jan 12, 2011 | 11:45 PM
DaveB's Avatar
There's your problem. You can't do that with the 3.5 gear or you'll flake out the CC. You need to reset the ECU or do a handful of restarts. It should clear. You need to disengage the CC before proceeding past 80mph or you risk this issue in most* 5AT's with deeper gears.
Old Jan 13, 2011 | 12:14 AM
NFSP G35's Avatar
? = 2B || !2B
Well, since you have this gear and you now know what causes it, you can do the footwork to get some more information on exactly what situations cause the cruise to wig-out.
For example: if you hit 85 with the cruise turned on but not set, does it freak?
Old Jan 13, 2011 | 07:06 PM
kyemaul's Avatar
Well daveb you are right the car is fine now after sitting for almost 12 hrs lol...... Now what did accur. While driving home I wanted to see the maximum mph that my cc would engage at. It engaged at 60mph also at 75mph and also at 90mph. Hhmm.. But after the 90mph try about 15 seconds in after cc set at that speed the problem came back any ideas for that or is simply that I cant cc above 85mph. All the other trys it set and cc just fine!!
Old Jan 13, 2011 | 10:06 PM
NFSP G35's Avatar
? = 2B || !2B
^No Nissan cruise will set over 90.
Granted, it won't freak out and stop working until you restart the car, just won't set.
You need to try setting it at 75, 80, 83, 86, 88 and see where the problem comes up.
Or, just start at 78, and hit the accelerate button one press at a time to increase it one mile per hr at a time until it gives a problem.
Old Jan 13, 2011 | 10:33 PM
Mustang5L5's Avatar
Are you saying Nissan cruise will set over 90, or that no Nissan cruise setup will set over 90.
Old Jan 13, 2011 | 10:36 PM
NFSP G35's Avatar
? = 2B || !2B
^There was no comma.
For all modern Nissan cruises, 90MPH is the highest speed you can set them to, or accelerate them up to. After that, they simply will not set. (Unlike my Trans-Am which was content to set at 140 )
Old Jan 13, 2011 | 11:36 PM
Mustang5L5's Avatar
Lol. I think I set the cc once in my mustang @ ~130 just to see if it would set. It did
Old Jan 14, 2011 | 12:16 AM
NFSP G35's Avatar
? = 2B || !2B
^Ah, good-ol domestics! Just hold the speed, whatever that speed might happen to be
Old Jan 14, 2011 | 05:39 PM
kyemaul's Avatar
I set mines at 90+ probably 93 or so it did set for aboout 15secs but I watched it set past 90...
