Drag Racing a Loaner (long)
My fellow G-folk:
The G35X went in the shop again to repair my flaccid steering column, creaking seat rails, and confused sunroof. When I show up, however, there is no loaner to be had. This is slightly surprising, as the appointment was scheduled around the availability of a loaner car. I push the issue and am informed that they will allow me the use of their “errand” car, not usually loaned out (and apparently used as a daily driver by one of the salesmen.)
Fully cheesed off by the additional ½ hour delay prepping the “errand” car, as well as not having my vehicle during one of the last racing weekends of the year, I come to the conclusion that my only option for automotive happiness was going to come out of racing the loaner.
“RACING A LOANER ?” you might shriek, “ABUSE” you might cry; I don’t give a rodent’s derriere…….I’m going racing.
The first problem is going to be the gas. I want to race with 1/8th to ¼ of a tank, and the damn thing is FULL! My only recourse (short of siphoning) is to make the trip to the track in 4th gear instead of 5th. This helps, but I can only manage 15-16 MPG and this leaves me with a half tank. Damn.
I did empty the windshield-washer fluid reservoir en route by holding down the spray lever. That should be good for a couple of pounds…
I arrive at the track about 30 minutes after opening, and it already looks to be a crowded day. My buddy and I stake out a spot to setup, and proceed to *strip* the loaner down. Out come the floor mats, spare tire, jack, tools, headrests, sound deadening material, ashtrays, and THE BACK SEAT. Taking into account my fat a$$, this car needs all the help it can get.
Under the hood, it is time to lose the engine cover and paper filter and install the K+N, purchased for this event. Yes, I am that sick. I am modding a loaner.
Not wanting any undue attention from the dealer upon return of their very fine vehicle, I think it wise to obscure their name and telephone number from the rear glass using shoe polish. Just try to imagine THAT phone call…..
Anyway, the car finally weighs in at 3580#, with my *koff* contribution of 247 pounds. Fine Swiss instruments tell me that this car is now hauling around 3333 pounds. Much better than my little porker of a G35x.
After an interminable wait (which allows for time to fine-tune the tire pressures), my first run nets a 14.83 @ 93 and some change. The run is made in MM mode with the shifts seemingly arriving at 7000 rpm. I know the car has to shift sooner than that by design, but with the lazy tach it is well into the red.
More than a few chuckles are heard when everyone is milling around the staging lanes, especially when they realize that the dealership’s “courtesy” is extending itself all the way to the dragstrip.
The long wait time between runs allows a full icing down of the intake manifold, achieving an even better 14.74 seconds at about the same MPH. This run makes me proud of my loaner, as we cut a .015 light and drop a few jaws.
Not being willing to commit to another hour and a half for a third run, we call it quits and reassemble the car. A little window solvent and some elbow grease later, the auto is back to servile duty as a common loaner car.
I would like to take this opportunity to throw down the gauntlet, as it were, to anyone who thinks they can beat that time with a G35 loaner/courtesy vehicle. I know it can be done, because track conditions (and driver conditions) can be improved upon. If anyone is able to do so, I will bestow upon them the sum of 35 cents and a certificate indicating their victory in the COURTESY CAR CHALLENGE.
Until then, I PILOTED THE FASTEST G35 LOANER IN THE WORLD !!!!!
Pics and timeslips to follow tomorrow.
'04 G35X Graphite/graphite, NAV, wood, premium
"May you lead an interesting life..." -- Old Gypsy Curse
Re: Drag Racing a Loaner (long)
That is the most craziest thing I have ever heard.
LOL
PS I think I might try it next time I have the loaner.
04 DG G35 coupe 5AT / z-tube / grounding wire gear / Unorthodox SS Pulley Set / next mod Plenum ...
LOL
I think you deserved it :-) well earned I may say.
And I bet the car appreciated it too.
This brings us to another fine point: "Don't EVER buy a used car unless you knew it, and the owner personally!"
Under the hood, it is time to lose the engine cover and paper filter and install the K+N, purchased for this event. Yes, I am that sick. I am modding a loaner. <blockquote><font class="small">In reply to:</font><hr>
HAHAHHA, man great story =)
Martin
2003.5 BS G35
Nismo Aero/Sport Package
0-60 5.4 - 1/4 Mile 14.16 *GTech* and on 19's!!
Martin
2003.5 BS G35
I've had a loaner for over two months, but I never did anything that crazy. Since the dealership accused me of blowing up my car, I didn't want them to accuse me of blowing up the freakin' loaner too!
Fantastic story! ROFLMAO!!!!!
Modding a loner! What year was it? A Sedan?
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars S/H. Sport Tuned Suspension
LOL skeleton, what happened to yours??
Martin
2003.5 BS G35
Martin
2003.5 BS G35
Cato:
The car was an '04 sedan.
Here are some pics
Here are some pics
more:
view of stripped out car.....
trunk.......
Here are the slips.....
Hey! That looks just like my car...
How difficult is it to remove the rear seat?
Easy!
If you see the 2 clips under the forward edge of the seat, simply pull on them to release the bench. You then tilt the front of the seat up and push the belts through the holes in the foam. Voila! No back seat.....
too funny.. it's time we added a new category to the TOP 5 Sedans and Coupes thread.
I've got the record for running 4 adults on the 1/4 mile .... now you've a record for running a loaner!
[img]/w3timages/icons/tongue.gif[/img] - Ted
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS - www.teamtransport.org/forums
