Removing Trunk Liner
Old Jan 30, 2011 | 01:03 PM
hL.'s Avatar
hL.
Exclamation Removing Trunk Liner
Hey, I'm trying to get my reverse lights out. I know the trunk liner removal is self explanatory. But I just can't pop the green "pull" T shaped lever out. This is the lever that opens the trunk from the inside.
Can anyone help?
Old Jan 30, 2011 | 02:22 PM
hL.'s Avatar
hL.
Anyone?!
Old Jan 30, 2011 | 02:34 PM
naughty240's Avatar
I use a plastic tool to pop it out. maybe a very small flat head will help. It has 2 spots that hold it in..
Remove cover and both lights are held in my 8mm bolts. After bolts are out you may need to apply a little bit of pressure to get the light to pop out.
Old Jan 30, 2011 | 02:36 PM
hL.'s Avatar
hL.
Thank you!! lol I wanted to make sure it can be popped out because I didn't want to snap the plastic and it's held really tight on my car.
Old Jan 30, 2011 | 07:19 PM
liljohnny's Avatar
Strange, I don't recall having to remove that to take out my reverse lights...
Old Jan 30, 2011 | 08:10 PM
High_Boost's Avatar
definately dont need to remove the liner, I just pulled 2 of the little platic retainers on each side and was able to pull mine easy enough
Old Jan 30, 2011 | 09:48 PM
hL.'s Avatar
hL.
Yeah, after removing the liner I realized this would've been much faster. Thanks for the help guys. This forum is the best.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
Oregon13
Mar 1, 2016 12:06 AM
