car starts then dies occasionally - runs fine and no engine light ??
Old Jan 30, 2011 | 02:39 PM
68_GT's Avatar
my wife's 04.5 G35X has 70K miles and will start up and occasionally the engine just dies. Sometimes it will do it 2-3 times in a row unless you push on the throttle some to keep it going. There is no engine light on and it otherwise runs great. Any ideas ?
Old Jan 30, 2011 | 06:54 PM
kyemaul's Avatar
Take the car to the dealer!
Old Jan 30, 2011 | 06:57 PM
Project's Avatar
Your throttle body needs to be cleaned. Probably wouldnt hurt to run some cleaner over the MAF sensor why you are in there.
Old Jan 30, 2011 | 07:36 PM
68_GT's Avatar
OK thanks guys, I run injector cleaner though her car here and there and I've been thinking to do the BG cleaning on the fuel system. Also her car has a pop charger air filter in it, I can't remember if the air filter is cleanable and reusable ????
Old Jan 30, 2011 | 07:37 PM
68_GT's Avatar
so they can charge me $300 for something I can do for $10 ?
Old Jan 30, 2011 | 07:38 PM
Project's Avatar
The popcharger is able to be washed and re-oiled.
Your throttle body is the big key there though. When mine was dirty the car would start and die right away. Or it would barely start and then idle almost at 500 then sometimes die. Theres a DIY on here on how to clean it just make sure not to smack the butterfly all around or you may have to replace it.
Old Jan 30, 2011 | 07:51 PM
68_GT's Avatar
sweet man thanks. I'll do it and report back.
Old Feb 15, 2011 | 11:09 PM
girlieg35's Avatar
My car is doing this same thing. Just posted a thread about it. I'm about to go crazy.
Old Feb 15, 2011 | 11:44 PM
itgogitrev's Avatar
Possible that your crank or cam pos sensor is on its way out.
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
ghost_g35
Aug 7, 2015 10:31 AM
ClwMike
Jul 23, 2015 12:55 PM
realtalk21
Jul 20, 2015 09:07 AM
