Please Help Heater Blows Cold Air When Warm Up
Old 02-01-2011 | 02:04 PM
brady89091's Avatar
So I Have A 04 G35 4 Door And It Is Very Cold Where I Live And I Need My Heater To Work And I Can Not Find Out Way It Is Not Working The Dealer Wants A Lot Of Money To Fix It They Say That It Is The Controls On The Heater That Are Bad But I Did Not Know If Anyone Has Had Is Problem Before
Old 02-01-2011 | 02:24 PM
thescreensavers's Avatar
Mr.202?
uh, so you cant move the temp to 75+ on the controls?
Old 02-01-2011 | 02:54 PM
geew1z's Avatar
do the hvac controls work at all?
Old 02-01-2011 | 03:05 PM
Deepdiver's Avatar
does your shift/caps key work at all?
Old 02-01-2011 | 03:19 PM
The X Factor's Avatar
Your car is warmed up while you're trying to get warm air, right?
Old 02-01-2011 | 06:32 PM
brady89091's Avatar
Yes the car is fully warmed up and the climate control can be set at 90° And it just blows cold air while idling When you're on the freeway it blows nuke warm air But nowhere near hot I thought it was the thermostat But it warms up fine on the Temperature Gauge cluster And I have Check the coolant system for air bubbles
Old 02-01-2011 | 06:38 PM
brady89091's Avatar
I believe the recirculating valve is electronic the control I was wondering if I put in an aftermarket radio that has aftermarket climate controls if that would fix it Or if it's the recirculating valve I just don't understand why it gets warmer on the freeway if the valve is Closed so Anti-freeze can't go through the heater core What are your thoughts
Old 02-01-2011 | 07:18 PM
bluedevils95's Avatar
you can always turn off the AC button.
Old 02-01-2011 | 07:49 PM
Mr.202?
Does it heat up with rpm?,
Old 02-01-2011 | 08:02 PM
Jeff92se's Avatar
Red Card Crew
1st to check is your radiator coolant level.
Old 02-02-2011 | 12:37 AM
brady89091's Avatar
It does not heat up with RPMs and the coolant level is at the correct level And yes the AC button is off
Old 02-02-2011 | 01:04 AM
fabb's Avatar
The same type of thing happens to me..after warm up i have to drive about 8-10 minutes for my heat to actually start working then its fine
Old 02-02-2011 | 02:23 AM
medianjoe's Avatar
I would check first if the right(passenger) side heater hose in engine room is hot or not.
Attached Thumbnails Please Help Heater Blows Cold Air When Warm Up-heaterpipe.png
Old 02-02-2011 | 10:54 AM
brady89091's Avatar
Okay if it is or isn't what do I do next And thank you again guys for Helping me out
Old 02-02-2011 | 01:46 PM
geew1z's Avatar
that hose presumably goes to the heater core, if it is not hot then the thermostat is shot. <- I believe that is what he is getting at.
Quick Reply: Please Help Heater Blows Cold Air When Warm Up
