Anyone still on their winter tires?
Been on my blizzaks for 2 months. For tires that are supposed to be grippy on snow, they are sure squirrely on wet pavement. Anyone else notice this?
I'd be doing 360s if I didn't have the TC on. Even on/off ramps have me tiptoeing the throttle
Mine was never squirrely on wet roads. they did have some roll when on dry roads when taking tight turns fast... Not the best handling tires, but never an issue on wet roads unless I was just driving like a moron...
Wait.....
Maybe.... just maybe......
Maybe your driving like a moron.....
Wait.....
Wait.....
Wait.....
Wait.....
Wait.....
Wait.....
Wait.....
But yeah, giving it 1/3 throttle(or less) is "driving like a moron". Good assement there
Yes I'm an admin on .org
1/3 throttle is all you need if your side stepping the clutch or in the case of a automatic sedan... neutral dropping it with the steering wheel cranked all the way.
I don't drive like you so no, this isn't the case, thanks.
I had the ws-50's on my 5.5Gen maxima before mounted on s14 5 lug rims in 16" and they were squirmy as hell and made an annoying humming sound over 45. BUT they were AWESOME in the snow.
Also, I just saw this last year, but you should bump up your tire pressure for your winter tires also
http://www.tirerack.com/winter/tech/...jsp?techid=168
I ran my ws50's between 30-32 psi cold.
Obviously I am sure you know to check pressure with the tire cold. But maybe try checking it in the morning before you leave for work.
