Car cuts off when idle
Old Feb 15, 2011 | 11:03 PM
girlieg35's Avatar
I'd appreciate any ideas about this. It seems to be getting worse. Additionally, it cut off while I was just driving slow not idle. There is no warning, no rocking, nothing. It just cuts off. I have a 2003 G35 sedan.
No engine light is coming on, so no one knows what the exact problem is. Please chime in.
Old Feb 16, 2011 | 07:41 PM
hi-tek22's Avatar
I had something like this happen on my 5th gen 2001 maxima a few years ago. I ended up replacing the IACV as well as the entire throtle body assembly. I know it would be perfectly fine if I revved the car above idle (or 1000 RPMS) but the moment the rpms dropped to about 700-850 RPM range, the car would instantly shut off.
For me the symptoms were: I would cut the car on, take my foot off the gas and then the car would simply die on me. Ive never experienced this with my g35 however I would suggest air intake or idle air control before all else.
I know on my buddies Q45 the same thing had happene to him and then the car would just die. Well he had a tear in his rubber throttle body assembly. I believe it was the area directly AFTER THE MAF.
I know others would say to clean the MAF... as the first thing when I had my maxima. Well I tried that also and it didnt work, as I was till having the exact same symptoms.
I know with my maxima, since it was a "cable" throttle body, and not a drive by wire like the G's are. People were telling me to cleant the throttle body...But since our G cars are drive by wire that might be a different story.
Old Feb 16, 2011 | 08:52 PM
TheCarbon26's Avatar
I would do an intake i did it on mine and it worked fine after that, but keep doin research before you spend money. im not saying that the intake would solve it. just keep researching a bit more b4 spending money.
Old Feb 20, 2011 | 06:12 PM
JimG35's Avatar
I'd clean the throttle body. Simple, cheap. It may do the trick.
champppy
Mar 31, 2020 12:25 PM
ghost_g35
Aug 7, 2015 10:31 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
Rehman2009
Jul 27, 2015 03:23 AM
