wow 60k ripoff.. confused..
Old Feb 25, 2011 | 07:24 PM
socialconflicts's Avatar
ok so went to get an estimate from the dealer some stuff i do not know exactly what they are.. this is what it came out to be
1,396.71
this is what would be getting done. this looks like 300-400 in parts.. tops.
Battery service load test
Bilstein Engine Clean / SVC -BILFL Whats this??
replace drive belts (this is just the regular belts right? not the engine belts?)
Differential Service (already done)
Deluxe Wash (LOL)
Fuel Injector Cleaning (do i need this?)
Throttle Body Service (should i get this done?)
Auto Transmission Service (already done)
Multi point inspection (free w/ Oil Change)
Replace Wiper Blades (thanks target)
Replenish washer fluid (isnt this a top off when oil change is done?)
Rotate and balance tires (LOL)
Replace Air Cleaner (not very hard...)
Replace Engine Coolant (Grant might do this for mee.. will be a drain and fill though..)
ADD MOC ENGINE TREATMENT (WTF is this?)
Replace Engine Oil + Filter (common)
inspect all of the following:
a/c hepa filter
all lights
power steering fluid
axle + Suspension
Brake pads + rotors
drive shaft + Boots
steer gear + linkage
exhaust system
horn operation (LOL)
Air Condition system
fuel lines + Vapor
can anyone tell me of those that i dont know what they are.
thanks all
Old Feb 25, 2011 | 08:49 PM
4D05G35's Avatar
"replace drive belts (this is just the regular belts right? not the engine belts?)"
Which belts are you thinking?
The drive belts would be the ones on the front of the engine for the A/C, PS,Alternator, etc.
Old Feb 25, 2011 | 09:19 PM
ldp82's Avatar
VQ has a timing chain anyways
Old Feb 25, 2011 | 09:36 PM
4D05G35's Avatar
True, thats why I was curious as to which belts he was thinking of.
Old Feb 25, 2011 | 09:53 PM
04G35NYC's Avatar
This is why you DONT go to the dealer!
Old Feb 25, 2011 | 10:13 PM
Matzo Ball's Avatar
hmm, I spent $683 for my 60k and got a rental G37x for 2 days.
Old Feb 25, 2011 | 10:24 PM
blazeplacid's Avatar
take that print out to a local mechanic, the price will be drastically different
Old Feb 25, 2011 | 10:44 PM
gary c's Avatar
First mistake was going to any Infiniti STEALERSHIP for service, what were you thinking? LOL It's a good idea to have all your fluids changed, those you haven't done recently. Brake fluid should be changed if you haven't done that recently. If you know a "reliable" independent automotive shop in your neighborhood they can change fluids, cost shouldn't be over $150. They can check your belts and only need replacing if they're cracked. Every thing else on the list if a rip if your G is running good! A couple years ago they used to include "Antenna Service" to their sheet....have you checked yours recently?
Gary
Old Feb 25, 2011 | 10:46 PM
3truman's Avatar
They did the same thing last time I took in my wifes armada for recall work, like $1400 for some inspecting and a few fluid changes. I said no thanks to the work but thanks for the list, I'll do it myself!
Old Feb 26, 2011 | 01:22 AM
CG4DR's Avatar
all a dealer does is look at their mileage recommendations are and say you need them. they don't actually look at the car. i work at a car shop and i know for a fact that most of the things that are recommended are off of mileage, not something you need. see if you serpentine belts are cracked, if not then don't worry. and then throttle body service and fuel injector cleaning should be included in the same price. at my shop we clean the throttle body with a spray and put in an injector cleaner via gas tank and a carbon clean via the vacuum system.
Old Feb 26, 2011 | 01:38 AM
thanks guys for all ur info, i was not going to do all at the dealer.. and i dont know a 'good mechanic' that i can 'trust' but does anyone know what these are? and if i need the TB cleaned (i rather have the dealer do it cuz i heard of bad idles after cleaning)
Old Feb 26, 2011 | 01:51 AM
CG4DR's Avatar
the engine clean is degreasing the engine, fuel injection and throttle body service is just a cleaner package, and the engine treatment is a chemical that is ran through the motor for like 5 minutes to break down sludge which is what full synthetic oil does or it will help stop leaks which most high mileage oils do
infinitiway
Aug 8, 2017 12:38 PM
f22raptor
Mar 18, 2016 08:50 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
miata007
Aug 17, 2015 04:36 PM
