Calling all sedans-What's your fender height?
Old Feb 11, 2012 | 01:44 AM
  #91
AARONHL's Avatar
Post 23 club
Old Feb 11, 2012 | 02:49 PM
  #92
iamtimshady's Avatar
Pics or it didn't happen.
iirc, ^ that pic was from before the alignment and I had adjusted the coils to an even 24" on all corners. I recently installed a rear camber kit, got different size tires and got my alignment done so the height in the rear changed quite a bit so I readjusted the height back to what I thought was 24".
I just went out and took the tape measure photos. Apparently my rears are uneven again, 24" and 24-1/8" . The front are technically now 24-1/16" almost an 1/8";
http://carphotos3.cardomain.com/imag...5854_large.jpg
http://carphotos4.cardomain.com/imag...5855_large.jpg
This is how she sits now though. Removed the front mudguards when I lowered it some more;
Can how much gas you have in your tank give you a gangster lean or did I forget to check the fenders after I adjusted the last time?
Old Nov 11, 2013 | 05:49 PM
  #93
805sfinest's Avatar
Originally Posted by P10 WRC
Okay, swapped out springs and i am at 25 1/8" F and 25" R on 350z eibach sportlines.
looks good did the front look higher when installed
Old Nov 11, 2013 | 05:51 PM
  #94
805sfinest's Avatar
looks good
Old Mar 26, 2014 | 11:19 AM
  #95
DRVNFAST's Avatar
25 1/2 front
25 3/4 rear
F&F coils
19" MRR wheels, 245 40 F and 275 35 rear
SPC Camber Rear
5mm spacers and Whiteline LCA and Compression rod bushings next on the list.
Old Apr 7, 2014 | 01:50 PM
  #96
G35-Silva's Avatar
I just got those bc racing BR for AWD infiniti
I love how you car looks and i was wonde if i could know you drop set up. I drope mine to much. I live in ny toad here are not that great. But i like how u car looks its nice
Old Apr 8, 2014 | 10:44 AM
  #97
Blue Dream's Avatar
I drove ttrank's car solo
He's on Function and Form coilovers.
Old Apr 8, 2014 | 11:16 AM
  #98
DRVNFAST's Avatar
Like Blue Dream confirmed, I have Function and Form Coils which allow for a crazy low drop. I have mine about an inch off the bottom of the rear cups (meaning I'm barely dropped) with these coils. If I wanted this thing to sit on the ground these coils would allow it. however this is my DD so that is less than ideal.
You are just going to have to play with them. I started low and have worked my way to this ride height after about 5 or so adjustments.
Good Luck
Old Apr 8, 2014 | 11:28 AM
  #99
G35-Silva's Avatar
Good Luck
Thank you for the info. I do have coil too. I just got the bc racing br type installed on my g35. I wanted the koni. But they dont made those for AWD. But i am loving this bc now however i had to hight up my car because it was to low i wasent able to drive without hitting my car with the gronw lol
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
alexbenz
Sep 26, 2015 11:30 AM
TeamNoSleep
Sep 13, 2015 07:40 PM
