'04 G35x Grinding noise when accelerating..help!
Old Mar 9, 2011 | 07:13 PM
skii's Avatar
Unhappy '04 G35x Grinding noise when accelerating..help!
Hi guys. I'm new, be nice to me. I recently acquired a 2004 G35x and I have had it for 3 months. However about 2-3 weeks ago, I've noticed a grinding noise coming from the front driver's side wheel area when I accelerate from a stop. Also, this noise gets even worse when the car shifts at about 2500rpm and the noise begins to level off when speed is picked up. What confuses me even more is the fact that this problem/annoyance is nonexistent when it is wet and rainy out, and sometimes the noise doesn't happen at all. Also, this only happens when the car is in motion, never when in park or neutral.
Metal on metal, or at least the sound of it does not excite me, and I would love some answers. If anyone has any info to offer, PLEASE I BEG YOU!
Thanks,
-Skii
Old Mar 10, 2011 | 03:58 PM
Machine Head's Avatar
is the grinding a constant or does it pick up in pace that faster you go?
Old Mar 10, 2011 | 05:30 PM
skii's Avatar
Pretty much the faster I go coming off of a standstill. it gets louder when i hit 2500rpm, and it goes away after that when speed is picked up.
Old Mar 10, 2011 | 05:42 PM
Blue Dream's Avatar
I drove ttrank's car solo
Might just be a bad wheel bearing. How many miles are on the car?
Old Mar 10, 2011 | 06:25 PM
skii's Avatar
I'm hoping that's all it is! She's got 84,000 with a fresh oil change.
And I vaguely remember having a noise like this in the same area on my '01 i30 from a bad ball joint. Hoping its just as easy of a fix.
Old Mar 11, 2011 | 01:59 PM
dphillips2011's Avatar
I've had that problem. It was the wheel bearing.
Old Mar 11, 2011 | 03:09 PM
Mustang5L5's Avatar
Wheel bearing, dragging/seized caliper, or halfshaft could be the culprit
Old Mar 14, 2011 | 12:17 AM
if it goes away at certain speeds it's the wheel bearing. A seized caliper would be a constant grinding + the smell of burning pads
Old Mar 14, 2011 | 02:47 AM
skii's Avatar
Guys, thanks for the help, I'm gonna get this fixed asap. So sick of scary noises.
Old Mar 14, 2011 | 04:05 PM
LuXXXz's Avatar
could be wheel hub
could be a stuck caliper bolt and its making the sounds once your car hits the ground at a certain angle you should check it out, make sure you take the caliper off and see if the bolts go easily in and out if not spray some wd40 in it clean it out and then grease it up and the brakes will run freely and might fix ur problem
Old Mar 14, 2011 | 04:06 PM
LuXXXz's Avatar
i had that problem w/ the front passanger side, i changed my pads and i just removed one bolt then rolled the caliper up but never checked it and it was grinding after i put brand new pads on it and rotors were good, i did that checkd it out and baam after that it drove like a dream
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
Claudiu
Sep 24, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
