Question about SPC shims
Old Mar 11, 2011 | 10:20 PM
mcaron's Avatar
Okay guys got a question about camber and these SPC camber shims. My car is lowered on BC coilovers and im pretty dam low, very close to maxed out. I've been useing SPC front camber arms without the shims. I've been thinking about selling my SPC front arms becuase i plan on going lower.
I'm not sure what the natural camber would be at when i lower my car with the stock arms but im assuming it would be more than -2 degrees.
So my question is if i lower my car more, use the stock a-arms and install the camber shims, i would NOT exceed the stock specs correct? Like my camber would still be in the negatives just a little bit closer to stock without using the SPC arms?
Sorry if this seems confusing, just trying to figure out my options. Thanks for your help everyone
Old Mar 11, 2011 | 10:30 PM
CandlestickPark's Avatar
ill Sedan
PM Grant (Gdup35Sedan). IIRC he is running SPC shims. Your natural camber should be more than -2 if you are slammed. I'm running natural camber up front and I'm at -3, lowered ~4".
Old Mar 11, 2011 | 10:31 PM
SN00P's Avatar
CLUB MODERATOR
yea im -3 front as well you can also PM cory (stormtroopa) he is running SPC shims as well . IIRC cory has only the shims and stock arms on the front and his camber is not crazy up from as me and Marcus and he is just as low as us
Old Mar 11, 2011 | 10:32 PM
mcaron's Avatar
haha MArcus i knew you would be the first to comment, and before i saw your repose, i PM'ed him :P haha way ahead of you :]
Thanks for the info, so if i added the shims and used stock arms i can prolly get my camber to around -1.5ish or better which i would be happy with.
Old Mar 11, 2011 | 10:33 PM
mcaron's Avatar
Also do you guys know if these add stress to the wheel bearings? I already blew 1 and dished out 200 for 1 front wheel bearing and i really dont feel like doing that again haha
Old Mar 11, 2011 | 10:34 PM
ill Sedan
Grant is lowered 4" up front and is at -2 camber IIRC with the SPC shims.
Old Mar 11, 2011 | 10:36 PM
SN00P's Avatar
CLUB MODERATOR
being slammed adds stress to a lot of things, bearings,bushing etc...
i just replaced a front hub and bearing the other week and waiting for the other side to come in so i can do the install on that.. but i didnt replace it from being slammed, i had another problem so i decided to just buy another side so i wont have any problems later on ..
sounds about right ..
Old Mar 12, 2011 | 12:21 PM
mcaron's Avatar
hmmmmm dont quite know what to doo, guess imma be running camber haha o well
Old Mar 12, 2011 | 04:48 PM
almost3flips's Avatar
Honestly dude just get your toe into spec. I'm running negative 2.4 front and 2.8 back and it's not so bad.
Old Mar 12, 2011 | 06:57 PM
G35Papa's Avatar
The SPC shims will give you a static +2 degrees of positive camber.
Old Mar 12, 2011 | 08:02 PM
CG4DR's Avatar
stock arms with spc shims dropped to ~24.25'' fender to ground i was actually within factory spec at a -0.5
as of now i have no idea bc i maxed out the front with the 20s but i am not wearing tires at all. i'd say i'm around ~1.5??
Old Mar 14, 2011 | 07:23 PM
mcaron's Avatar
stormtroopa do you have problems with your ABS?
A member tod me he had severe probems with his ABS after he instal just te shims
Old Mar 14, 2011 | 08:00 PM
xxxxxxxxxx's Avatar
is it really worth buying then a front camber kit if you are drop more than 3 inches?
Old Mar 14, 2011 | 08:02 PM
CG4DR's Avatar
At first I had an issue but it was because I took chunks out of the bearing. The other member probably didn't use te spacers properly
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
