Replacing padded piece above upper glove box
Mar 13, 2011 | 10:27 PM
I searched the forum and couldn't find what I was looking for.... possibly because I don't even know what to call it.
In short, the padded area above the upper glove box is coming loose (again). I have glued it a couple of times, but the corners of the padding continue to pull away and I would like to see about replacing the whole unit instead of gluing it back.
Anyone have any ideas?
Reply 0
Mar 13, 2011 | 10:40 PM
any pics?
Reply 0
Mar 14, 2011 | 02:04 AM
have you tired using a two part epoxy?? 3M makes an epoxy that once it dries it sticks FOREVER. i'd give that a try
Reply 0
Mar 26, 2011 | 03:55 PM
I actually determined its the upper glove box lid that needs to be replaced... which I find means you have to order the entire upper glove box assembly. $300!!
Reply 0
Mar 27, 2011 | 06:57 PM
I used Gorilla Glue on mine and it worked a charm!
Reply 0
Mar 27, 2011 | 09:22 PM
I used Gorilla Glue on my previous car when the trim/padding on the airbag started warping away from the airbag. Worked very well, the only tough part was getting clamps on it.
Reply 0
