2005 G35 - Battery drain - Bose - DIY Fix?
Old May 8, 2011 | 01:25 PM
Cardinal's Avatar
Thats exactly the DIY that I used! Basically the same disc player that is in the G. Take specific note in his picture where the inner ribbon cable is the problem. I did the repair I had nothing to lose. Apparently the cable gets worn and the contacts either separate causing channnel loss or touch each other causing amperage draw(short). I can't comment on what the repair shops do, they say they use upgraded parts! to fix problem. But I read several people had thier changer repaired only for it to have problems in a year or so later.
Old May 8, 2011 | 03:18 PM
Cardinal's Avatar
As NFSP G35 stated in the 3rd post he removed his cd head unit and the power drain was fixed. If you're feeling adventurous and want to save a couple of bucks, PM me and I can get you the service manual (10.2 mb file).
Old May 13, 2011 | 03:28 PM
avinashchanagal's Avatar
Originally Posted by Tollboothwilley
Punch the head unit....and then kick it if that doesn't work.
Old Feb 6, 2022 | 09:44 PM
normnicol's Avatar
G35 2005 Sedan
Bose radio
is it the service manual for the radio or the car, if it is for the radio I am interested if you still have it
Old Feb 6, 2022 | 11:09 PM
05_SkylineSedan's Avatar
20 Year Member
https://www.nicoclub.com/service-man...F2005%2Fav.pdf
scroll down below the displayed window and click on "Click here to download a copy"
laksjd84
Feb 28, 2026 01:58 PM
Blakelyg35
Aug 15, 2015 12:12 PM
lemmy999
Jul 25, 2015 12:13 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
