would a 3.54 final drive off my 2006 Manual 350Z, fit on a 2005 G35X (AWD)?
Old Mar 19, 2011 | 07:52 PM
show2nite's Avatar
Would a "3.54 final drive off my 2006 Manual 350Z " fit on a 2005 G35X (AWD)?
Old Mar 19, 2011 | 10:20 PM
3truman's Avatar
I don't believe so. different front and rear gears would create a problem. Rears would spin slower than fronts when awd is engaged. Higher ratio will mess up vdc and awd together
Old Mar 19, 2011 | 11:12 PM
show2nite's Avatar
Thanks 3truman! for the info.
Old Mar 20, 2011 | 12:15 AM
NFSP G35's Avatar
? = 2B || !2B
^+1
You would have to change the final drive of both front and rear at the same time... I haven't heard of anyone doing that in the G world.
I know Subaru guys do it sometimes, but it's neither cheap nor easy.
Old Mar 20, 2011 | 12:37 AM
3truman's Avatar
My buddy has a jeep and he wants to change his gears too, 4X4 has to change both so we've been talking about it a bit, easy for me to respond. Glad to help
Old Mar 21, 2011 | 08:28 PM
mkvl127's Avatar
do the 350z 3.54 final drive in the front and back
Old Mar 21, 2011 | 08:29 PM
NFSP G35's Avatar
? = 2B || !2B
^no
Old Mar 21, 2011 | 11:55 PM
DaveB's Avatar
The X already has the 3.54 gear set, front and back. So yes, it will work. The only advantage to this swap would be if the pumpkin you're swapping in has a VLSD.
Old Mar 22, 2011 | 01:46 AM
4DGS's Avatar
Zinger
Old Mar 22, 2011 | 02:18 AM
Tollboothwilley's Avatar
No it won't work. At least not without modification. The G35X has a different pumpkin than the rest of the G35's - like everything else.
Like mentioned aboved - the G35X come standard with 3.53 gearing in both front and rear differentials - both are open diffs.
Old Mar 22, 2011 | 11:26 AM
DaveB's Avatar
What's different about the X pumpkin?
nickmcc123
Lights
Oct 7, 2017 12:18 AM
socalg35x
Jul 28, 2015 10:42 AM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
