stock tires question
Old Nov 12, 2004 | 11:05 AM
cantdrv55's Avatar
How long should the stock tires last if the car will never be autocrossed and just used a daily driver? How does a comparable set cost? Thanks.
2004 FX45 w/tech, aftermarket hitch, Thule crossbars and bike rack
Old Nov 12, 2004 | 02:44 PM
Q45tech's Avatar
Re: stock tires question
Tire life depends on road composition and roughness, temperature and inflation, speed, and stops/accelerations per mile. Owners commute , job, and style.
Different people go thru brakes and tires at different rates, not unusal to see a 20,000-35,000 mile range for tires on same car all driven by ADULTS.
Nissan like to use soft tires as oem to gain performance in magazine test but most last at least 20,000 miles till the tread wears to 2/32" unless owners don't rotate, flip, and do alignments every 6 months.
Anything over 20k is a gift!
Old Nov 12, 2004 | 03:14 PM
iafzal's Avatar
I have 27k on my G35s and still about 4/32 tread on it.
It should last about 5-10k more for me. I have Bridgestone 17" OEM tires.
2003 G35 Black Sedan
Old Nov 12, 2004 | 03:50 PM
GBoy's Avatar
Hi Qtech45, can you tell me if you can install springs only
from a coupe to a sedan running with the sport shocks..
Thanks
GBoy
2003 Sedan/Black/Black
Coupe suspension
Z pipe/KN filter
Grounding kit/Clear corners
Old Nov 12, 2004 | 04:25 PM
SixFive's Avatar
"alignments every 6 months"
I average about 1 alignment every 4 years as I am a stickler for avoiding alignment killing crevices and curbs if at all possible. Also, I thought the G's suspension was designed to be alignment friendly in the way the springs are not over the shocks or something...care to shed more light?
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
realtalk21
Jul 20, 2015 09:07 AM
mushu
Jul 15, 2015 03:55 PM
