Memory help
Old Apr 7, 2011 | 01:52 PM
kayveeee's Avatar
Angry Memory help
I just changed my battery and now my seat won't automatically adjust itself when i turn the ignition off and open the door. (I have premium model)
Yes, I did read the manually and searched and set everything correctly, the indicator light is fine with what i read but it will not move back to the original position when i open the door and adjust itself to the position I made it memorize to be when i turn the ignition on.
I don't know if I make any sense because im pretty **** how complicated they made everything for this car
I just want my automatic memory seat back!
Old Apr 7, 2011 | 05:48 PM
Abax84's Avatar
Its like your radio presets, once the battery has been completely disconnected you have to restore everything manually. Just move your seat to where you want it, and add it to the memory... Its not that complicated, might take you a whole minute.
Old Apr 7, 2011 | 07:31 PM
commadanteb's Avatar
Appears you need than just memory help
Old Apr 7, 2011 | 11:08 PM
kayveeee's Avatar
It's not the memory seat thats the thing...what ima tryna say is it won't adjust itself automatically even when it says i DID set the seat to what I want. Like when you get out of your car it the steering wheel wont move up by itself n the seat dont move back like it used to be back then automatically.
I know how to set the seat, thats not the issue.
Old Apr 8, 2011 | 10:52 AM
ridinG's Avatar
Make sure you don't have the automatic position cancel switch on.
Old Apr 8, 2011 | 10:54 AM
kayveeee's Avatar
^^ nope its on automatic, i've tried everything in the book correctly, it just doesnt have the entry/exit function anymore =[
Seems like noone knows how to fix this issue, guess its time to visit the stealership...
Old Apr 8, 2011 | 10:57 AM
ridinG's Avatar
Disregarding the opening-the-door part, if you're sitting in the car, "memorize" that current position, then move the seat manually to some other position, and then hit the button so that it goes to the memorized position - does that work?
Old Apr 8, 2011 | 10:59 AM
kayveeee's Avatar
Nope, and when i tested it out see if it actually set to what i want the light lit up for 5sec meaning its set but it really didnt.
Old May 4, 2011 | 01:40 AM
jattg35's Avatar
i am having the same problem! my battery cable was loose and i fixed it and then i had to reset my memory seats and now when i get in and out of my car it doesnt go back and forth automatically like it used to. its really bothering me!
mtlruss
Dec 20, 2015 01:51 PM
zcherub
Sep 10, 2015 12:03 PM
pasjr1972
Sep 1, 2015 10:17 PM
SFLG35
Drivetrain
13
Apr 26, 2004 11:31 PM
