My popcharger has melted
Old Apr 7, 2011 | 07:46 PM
-= SKiZO =-'s Avatar
Well after 3 years the glue that holds that rubbery stuff from the JWT heatshield to the intake has decided to give way.
Considering my car is stock apart from the intake, I hoped it would last longer.
Anyone else had this problem and what did you do to replace it?
Cheers.
Old Apr 7, 2011 | 08:08 PM
Tollboothwilley's Avatar
Its the crappy glue that JWT uses for the rubber
I replaced it through JWT by calling them - you can also glue it back together if you didnt lose it all
Old Apr 10, 2011 | 07:31 PM
I did something stupid and threw it away in disgust(it was in for a rego inspection when I noticed it). It never fit properly anyway - what's with that?
I'll see if they are kind enough to replace it for me as well. It's a shame, I think the quality of the pod itself is very good.
Cheers.
Old Apr 11, 2011 | 01:09 PM
Nyteowl's Avatar
i threw mine away a long time ago..
Old Apr 11, 2011 | 08:18 PM
Blue Dream's Avatar
I drove ttrank's car solo
Just another reason not to use a pop charger.
Old Apr 12, 2011 | 01:24 AM
jookyshank's Avatar
I haz hugz to givez
Sounds like a pop but is held together with the hose clamp type ring so no glue to wear out
Old Apr 12, 2011 | 09:20 AM
Wow, looks like you have a CF fetish. Very nice.
But is the shroud/heatshield hooked up to the intake, it doesn't look like it from this photo or have you piped some extra intake?
Thanks for sharing.
Old Apr 12, 2011 | 03:53 PM
jookyshank's Avatar
I haz hugz to givez
Once I get my comp hooked back up I'll put a newer pic up ...after a tune on the dyno it was suggested that I make the ram functional again to alleviate heat soak as much as possible so we rotated the intake so that it perfectly utilizes the ram and blocks the...well...the block as a real heat shield should!
And yea cf is kind of an obsession
hehe someday...Mansory ...I shall own one of you
Learned Hand
Oct 1, 2015 09:02 AM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
n1smojunkie
Sep 7, 2015 02:42 AM
CrazyLogic219
Aug 13, 2015 06:40 PM
