05 Sedan Suspension HELP!
Old Apr 21, 2011 | 11:16 PM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by DrewLe
Depending on the shocks/struts you have, if you have sport shock/struts. You can go with the G/Z combo (front Z springs and rear G coupe springs), which will give you a mild even drop.
Be careful, once you do a mild drop now, you'll want to go moar low later...
I have a full revised Z suspension and love it.
^I can +1 everything in this post
Old Apr 22, 2011 | 12:04 AM
thescreensavers's Avatar
Mr.202?
G/Z setup is hard to get, just get revised Z springs which is the same drop
which is the setup I run. No kits needed
jsimonk
Dec 22, 2023 03:49 PM
tiguy99
Mar 1, 2016 11:42 AM
si_driver
Aug 11, 2015 07:08 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
CJay
Aug 1, 2015 03:57 AM
