Egg Smell.
Old Apr 13, 2011 | 10:36 PM
Julio00017's Avatar
Egg Smell.
Lately when I get out of my car, while the car is on, I can smell this egg scent coming from underneath my car. Anyone had this problem and fixed it? I drive a 2004 G35x sedan.
Old Apr 13, 2011 | 11:08 PM
speedracerg35's Avatar
catalytic converters probably going bad.
Old Apr 14, 2011 | 12:31 AM
4D05G35's Avatar
Yep, Cats are bad
Time for some HFCS..
A lot of people like Berk.
Old Apr 14, 2011 | 12:49 AM
luvmyzx6r's Avatar
Not necessarily. You could just have a leak around The Cat. try replacing the gaskets first. If your cat is the culprit, you'll have some funky idling and slow throttle response with poor gas mileage.
Under heavy throttle, a little egg smell (sulfur) is normal. Egg smell from Idling and normal driving means leak or bad cat.
Old Apr 14, 2011 | 05:58 PM
TIRE_SMOKE96's Avatar
is the HFCS legal?
Old Apr 14, 2011 | 09:59 PM
4D05G35's Avatar
Not necessarily.
I have never had an egg (sulfer) smell under heavy throttle with a good cat. Ive gone through my fair share of cats (12+) mostly due to a rich condition caused by F/I.
OP, if you have the means check out the gaskets, but I believe that you will find that that cat is the culprit.
Old Apr 14, 2011 | 10:01 PM
4D05G35's Avatar
Originally Posted by TIRE_SMOKE96
is the HFCS legal?
Most all HFC's are legal. It's the " Test pipes" that arnt.
Stick to the quality ones such as berk.
Old Apr 14, 2011 | 10:05 PM
SDGenius's Avatar
might be ur battery
Old Apr 15, 2011 | 02:31 PM
Julio00017's Avatar
any good brands for a new cat?
Old Apr 15, 2011 | 03:18 PM
luvmyzx6r's Avatar
Originally Posted by 4D05G35
Not necessarily.
Gaskets deteriate over time so alittle sulfur smell under hard acceleration will be noticed. Pathfinder, 4runner even my dads old es300 did it.
Old Apr 15, 2011 | 05:01 PM
DaveB's Avatar
Rotten egg smell is entirely normal. The cats are working fine.
Old Apr 15, 2011 | 08:12 PM
DrewLe's Avatar
OP, check your warranty. I think the cats are covered under an 8 year/ 80k mile warranty. If your under that, the dealer should replace them at no charge. I didn't have to pay for mine when I had an issue with them.
Old Apr 15, 2011 | 10:52 PM
5150DS's Avatar
is the HFCS legal?
Probably, unless you live in a state that goes by CARB rules.
njg356mt
Nov 3, 2005 09:03 PM
rage777
Southern California
18
Nov 2, 2005 06:55 AM
IS300TOG35
Aug 12, 2005 12:19 AM
TVR_G35
Apr 15, 2005 09:52 AM
