Anyone else had this problem?
Old Apr 18, 2011 | 01:45 AM
publet's Avatar
My driver's side rear wheel is about half an inch lower than the passenger side rear wheel. Has anyone else experienced this or know how to fix it?
Thanks!
Old Apr 18, 2011 | 01:48 AM
Cone's Avatar
might be your springs and bushings, try swapping the springs to see if the lean swaps as well.
Old Apr 18, 2011 | 01:53 AM
HwyDrftr's Avatar
You mean the fender, right? Were you parked on level ground?
Old Apr 18, 2011 | 01:54 AM
publet's Avatar
i suppose you could say the fender. Basically the distance from the tire to the fender. I was parked on level ground.
Old Apr 18, 2011 | 01:58 AM
Cone's Avatar
yeah one of your springs might be shot. or someone fat sitting in the back seat.
Old Apr 18, 2011 | 01:59 AM
HwyDrftr's Avatar
Well the tire only can go lower if it is flat or in a hole
I'd park some where else and measure again. Stock springs? Could be that the spring is not seated in its base correctly.
007JD's Avatar
i actually have the same prblm.... but for me i think its cause i got 4 different wheel =/
Old Apr 18, 2011 | 02:02 AM
drkay's Avatar
I have the same issue. Probably a bit more pronounced. I ignored it cause I dont know what to do about it and it's gonna cost money.
Old Apr 18, 2011 | 02:05 AM
publet's Avatar
lol there was nobody sitting in the back.
stock sport springs. i guess i could check the spring seating
Old Apr 18, 2011 | 02:51 AM
Vancouver_G35's Avatar
I actually have this problem and I noticed after I lowered it a bit. When I had my coupe 19" wheels, one the right side it never rubbed but I noticed that it would on the left (driver's) side. When I got the alignment done 1 month after the drop, the tech said he noticed the car wasn't even left to right. I was resting on the lift so the wheels, suspension or tires wasn't the issue, the frame body was literally sitting lower on one side on the frame itself. He asked me if I had been in an accident and I said nothing that would warp the frame, certainly not on one side. A manufacturing mistake perhaps? Not like its covered under warranty now. Heh.
Old Apr 18, 2011 | 12:58 PM
Abax84's Avatar
^So you dont know what the issue was? Did the alignment fix it? I noticed mine rubbing on one side only, and sometimes I think I spot a little lean.
Old Apr 18, 2011 | 01:45 PM
AARONHL's Avatar
I think I have the same situation.
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
