Heating/Cooling switch
Old Nov 17, 2004 | 06:55 AM
shibra's Avatar
is there a way to change the heating seat from heating to cooling??!!
I live in prety hot/worm state, and I rearly use the heating feature.... but as for cooling, i see myself using it very often...
and add to the fact that i got black seats....
Old Nov 17, 2004 | 08:24 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Re: Heating/Cooling switch
Yah..
It's an easy fix.
Just reverse the polarity so that the electrons run in reverse.
That way they'll take the heat out, instead of putting it in. [img]/w3timages/icons/wink.gif[/img]
<font color=blue>04 Silverstone G35, 5AT, Prem, Aero
ES100 225/45-18 front 245/40-18 rear
HKS & Y-pipe, Z-tube, Eibach, 35%Tints</font color=blue>
Old Nov 17, 2004 | 08:34 AM
g4ian's Avatar
I can't imagine living in a hot/worm state-I think being hot is the smaller of the two problems. I would focus your energy on trying to get the worms under control. Maybe you could convert the seat heater switch to a switch that sprays a worm killing pesticide....or use that reverse polarity thing to create an electron beam an fry their a$$. Hope you can get your worm situation under control.
As for rearly using the heating feature- Isn't that statement kind of redundant...of course you use it on your rear! Infiniti got it right when they put the seat heaters where your butt goes.
Hope all my smart a$$ comments have helped
Good luck,
g4ian
g4ian<P ID="edit"><FONT class="small"><EM>Edited by g4ian on 11/17/04 05:39 AM.</EM></FONT></P>
Old Nov 17, 2004 | 09:15 AM
cato's Avatar
SouthernComfort Moderator
I started to reply to this post in a smart-aleky tone,
but thought I would just sit back and watch the flames!
This bon-fire is still growing, where are the marshmellows?
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars S/H. Sport Tuned Suspension
Old Nov 20, 2004 | 04:57 AM
shibra's Avatar
inTgr8r,
Have your tried it (or know someone that did)...
Do you know how to do it? dealer?
I dont want to miss with electrons and then be setting on an oven all day long....
Not only marshmellows would be on the menue, prety much every thing esle would also be there...
Old Nov 20, 2004 | 05:54 PM
InTgr8r's Avatar
shibra
Just kidding....[img]/w3timages/icons/smile.gif[/img]
Seat cooling is an entirely different function
requiring cool air ducting from the A/C system.
Old Nov 20, 2004 | 07:40 PM
Gordgee's Avatar
Administrator
It would also require different cushions with perforations in the foam and perforations in the leather seat surfaces. Then you'd also have to wire in a fan to circulate the air through the seats.
Anything is possible, but it just takes money. The easiest way would likely be to get a set of seats from a wrecked car that has the seat coolers. Of course you'd then have to fabricate mounts, controls, etc. You could also check with a re-upholstery shop to see what they say re retrofitting your current seats.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Nov 20, 2004 | 11:37 PM
shibra's Avatar
it seems that it needs a lot of work and money...
if it was a simple job, it would have been worth it...
Thanks every body for your comments...
chow
Dallsinghjr1
Sep 17, 2023 11:25 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
itgogitrev
Sep 23, 2015 07:08 PM
