Emergency Trunk Release
Old May 1, 2011 | 01:14 PM
MidnightG35's Avatar
My trunk recently stopped opening...keyfob, button, everything. And to top it off my glow in the dark emergency tab broke off! Is there another emergency trunk release? How can I open my trunk? Please help!
(2004 Sedan)
Old May 1, 2011 | 02:48 PM
UCIMAplaya2's Avatar
I don't know if its the same for the sedans, but on the coupes there is a red strap hidden in the center of the back seat. Its in the crack where the seat back meets the seat bottom. If you pull that you can drop the rear seat from inside the car. Crawl in and pull the glow in the dark emergency tag and the trunk should open. Hope that makes sense
Old May 1, 2011 | 06:44 PM
Blue Dream's Avatar
I drove ttrank's car solo
Not the same in the sedan, the seats don't fold down. OP I'm clueless, sorry.
Old May 1, 2011 | 06:55 PM
togee's Avatar
That happened to me although I had the glow in the dark thing. Couldn't reach it - need a 10 foot long arm - so I bent a wire coat hanger, reached in and flailed bout until it caught on something, then pulled and the trunk opened.
Old May 1, 2011 | 07:00 PM
thescreensavers's Avatar
Mr.202?
On 05 model there are 2 tabs to pull, in 03 I know the glow in the dark is impossible to grab by hand from the pass through.
Old May 3, 2011 | 06:50 PM
drillers's Avatar
Not shure your 04 is the same but >> My 05 6MT has a switch for the trunk door motor on the L-side when opening the lower glove compartment .If the switch is inop. unplug the switch from the back and bridge the two pins together with a piece of wire - it should pop the trunk for you .
Old May 3, 2011 | 07:16 PM
DJ Encore's Avatar
Talking
That should work! if not find yourself a Puerto Rican. he'll pop it in no time!
Old May 3, 2011 | 07:32 PM
drillers's Avatar
Woops , forgot to mention to press the trunk release button after you bridge the two contact pins .
As mentioned above a P.R. Would be an Awsome
option also ! Lol
Old May 7, 2011 | 01:42 PM
Lol. Thanks. I'll give it a try.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
