bc coilovers maxed out but want moar low
Old May 20, 2011 | 10:32 PM
4DGS's Avatar
Yea 24" might be the max for BCs, I'm a couple threads from maxed with all collars in and spec preload and I'm at 23.8 in the front.
I know for a fact BCs don't go as low as Stance. So I'd say start chopping collars or start looking for new coils.
Old May 20, 2011 | 11:12 PM
FlyingLumpia's Avatar
run some neg preload or get camber arm and run more camber.
Old May 20, 2011 | 11:30 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
You can lower the spring but you'll lose pre-load which will give you a bouncy, ****ty ride.
Sounds like you're maxed out. Your car looked good from the pics, no need to go lower on the front or rear.
I'm on Stance LX+ (24" up front and 24.5" in the rear... I also haveuch taller tires than you though. 215/225/45)
Old May 20, 2011 | 11:49 PM
xxxxxxxxxx's Avatar
yeah i dont wanna lower the preload.
question: if i add 5mm to the preload would the car raise?
Old May 21, 2011 | 12:03 AM
I want to say yes.
Old May 21, 2011 | 12:22 AM
forweareLegion's Avatar
Yes it will. If you want to go lower buy Stance haha. Taking out the middle collar should fix you up if all the collars are together.
Old May 21, 2011 | 12:35 AM
xxxxxxxxxx's Avatar
i guess ill stay at the hight im now
what i really want later on are the stanceworks coilovers those look bad azz
Old May 21, 2011 | 02:40 AM
ATL_Red_G35's Avatar
okay, couple things here:
by max out, you mean B and C collars are now touching each other or that the shock cartridges can't go any lower and there's spaces between B and C like the picture shown?
if it's the later, what you would need is shorter cartridges.
DO NOT remove B collar as it's the locking piece.
If it's the first scenario, then you can get shorter springs.
Old May 21, 2011 | 02:46 AM
xxxxxxxxxx's Avatar
the shock wont go lower.
MannyFresh's Avatar
You can remove 2 collars, which ones I forgot.
I had D2 coilovers on rsx type s and it didn't give me the drop I wanted so I removed 1 collar which gave me about 1" drop.
Old May 21, 2011 | 02:53 AM
xxxxxxxxxx's Avatar
yeah but i dont think it would make that much of a difference , i think ima just leave it like that
Old May 21, 2011 | 10:34 AM
4DGS's Avatar
You can remove any collar you want once your maxed out because the spring has no where to go. Locking collars are irrelevant when large amounts of force are applied. As long as the lower perch is twisted in as far as it can, it can't go anywhere...
Old May 22, 2011 | 11:54 AM
GreenGoblin's Avatar
The goblin resurrection
Here is a pic of a maxed out stance coil.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
invincible514
Sep 21, 2015 07:05 PM
joeslates
Sep 11, 2015 11:19 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
Jnm07
Sep 5, 2015 01:16 AM
