bc coilovers maxed out but want moar low
Old May 20, 2011 | 04:52 PM
xxxxxxxxxx's Avatar
i maxed out my coils but it wont let me go lower. can i take out a collar or something to go lower? if so which one?
p.s that not me btw lol
Old May 20, 2011 | 04:59 PM
Siaon's Avatar
Shorter springs?
Old May 20, 2011 | 05:05 PM
G35Papa's Avatar
The bottom collar is the one used for adjustments. If it was maxed out, it should be all the way up, towards the top collars.....unless there is no more thread on the strut? I can't tell from the pic
Old May 20, 2011 | 05:13 PM
xxxxxxxxxx's Avatar
the strut is all the way down already
Old May 20, 2011 | 05:17 PM
GreenGoblin's Avatar
The goblin resurrection
The locking one on the top, so from the top down the second
Old May 20, 2011 | 05:20 PM
xxxxxxxxxx's Avatar
so b?
Old May 20, 2011 | 05:23 PM
Is that maxed out? It will not thread any more into the body? Removing any of the collars will not help, if the shock tube is maxed out in the body.
Old May 20, 2011 | 05:37 PM
bluedevils95's Avatar
If you want to go lower, you can always get airbags and you'll be as low as you want.
Old May 20, 2011 | 06:08 PM
xxxxxxxxxx's Avatar
thats not my car
and yeah the shock is maxed out in the body, i cant spin it no more.
and naw bags are for groceries , static all the way
Old May 20, 2011 | 06:28 PM
G35Papa's Avatar
Ah I see...I thought that was a pick of your strut. Sounds like you are truly maxed out.
Old May 20, 2011 | 06:34 PM
4DGS's Avatar
That was a dumb a useless comment....
Is collar "C" all the way up against Collar "A" and "B"?
You can remove collar C and have collar A and B sit on the top of the perch. If you need even more you can remove collar B. If you remove both it will give you about another inch.
BTW, is this front or rear? You didn't specify if it's a true coil rear or actually the front.
There is a tonne of guys slammed on BCs so you must be doing something wrong.
Old May 20, 2011 | 06:57 PM
xxxxxxxxxx's Avatar
I dont think removing C would do nothing since its just like a lock to the struck wont move,
And im talkin bout the fronts.
Old May 20, 2011 | 07:00 PM
4DGS's Avatar
It will because it will allow the strut perch to sit closer to the other collars therefore making the strut shorter.
Pull out collar B and see if that's enough for you.
Also, go measure your front fender to ground. I just remembered you're on 18s and there isn't anyone slammed on 18s except Grant and I and we're both on Stance coils (which go much lower than BCs)
Old May 20, 2011 | 07:12 PM
xxxxxxxxxx's Avatar
im at 24" fender to ground -___-
Old May 20, 2011 | 07:30 PM
CandlestickPark's Avatar
ill Sedan
Based on my ride height in the rear on BCs (24 3/8") sounds like you are maxed out. I've heard of people removing the collars to go lower, but honestly I'm not sure which one.
