question on the coupe midpipe
Old May 21, 2011 | 03:23 PM
jingber05's Avatar
i currently have an 04 sedan with a resonator delete with a aftermarker muffler but i want to get rid of the resonator delete because it is too ricey.im buying a coupe midpipe tomorrow but is it a direct bolt on? the seller says he doesnt have the bolts for it. Do i need to buy new bolts now? or will the exhaust shop figure it out?
Old May 21, 2011 | 03:27 PM
thescreensavers's Avatar
Mr.202?
Its a direct bolt on if you had a stock set up
Old May 21, 2011 | 03:28 PM
jingber05's Avatar
so what do i need to buy now?
Old May 21, 2011 | 03:31 PM
Mr.202?
I have no idea how your "Custom" exhaust is set up. So I have no idea.
Is everything bolted up like OEM, or is it all welded up.
Old May 21, 2011 | 03:32 PM
jingber05's Avatar
the straight pipe that replaced the OEM resonator is welded on
Old May 21, 2011 | 03:33 PM
JaE35's Avatar
Moderator
G35 Sedan
You can use your old bolts, no problems at all...don't need to buy anything extra
Old May 21, 2011 | 03:37 PM
Mr.202?
Since you welded everything up, you need to go to an exhaust shop rather then just swapping some bolts out.
Old May 21, 2011 | 03:42 PM
jingber05's Avatar
thanks u guys.appreciate the help
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
kd03g99
Jul 30, 2015 11:24 AM
mushu
Jul 15, 2015 03:55 PM
