OBD II P0430 Probelm HELP :-(
Old May 25, 2011 | 11:56 PM
poloavirex's Avatar
My emission is due in a Month i got this code p0430 Autozone and Nissan tech are telling to change the Cat but that thing cost $900 i went to a Muffler shop and guy said he can customize me a cat and will only cost $200
What should i Do??????
Buy the Nissan Cat or go with the Customize?????
HHHHHHHHHHEEEEEEELLLLLLLLLLLPPPPPPPPPPPPP:confused 2:
Old May 26, 2011 | 12:02 AM
bigjee's Avatar
Search for the cats here;
Exhaust classified
Old May 26, 2011 | 11:26 AM
str8dum1's Avatar
try a defouler 1st
Old May 26, 2011 | 06:45 PM
poloavirex's Avatar
what is a defouler???
Old May 27, 2011 | 08:59 PM
Mustang5L5's Avatar
Most often, that code is not a failed o2 sensor, but an exhaust leak.
Basically the computer is looking at the upstream cat and downstream cat and comparing readings. An exhaust leak here can cause this code.
Is the cat or any pipe or weld rotted out?
Old May 27, 2011 | 10:21 PM
poloavirex's Avatar
Mustang i think maybe the issue when i'm driving it sound like there is a tiny hole and my Pickup it sucks and when i check my spark plugs last year they were black and they were only in the car for about 4 months
Old May 28, 2011 | 01:58 AM
DaveB's Avatar
P0430 (Bank 2)
Defined as "Catalyst system efficiency below threshold"
Either:
Three way catalyst 1 does not operate properly, or
Three way catalyst 1 does not have enough oxygen storage capacity.
Possible causes:
-Three way catalyst 1
-Exhaust tube
-Intake air leaks
-Fuel injectors
-Fuel injector leaks
-Spark plug
-Improper ignition timing
Simple checks recommended in the FSM (service manual):
1) Check for an exhaust leak between the manifold and cat
2) Check the intake tract for air leaks after the MAF.
3) Have the base ignition timing checked
4) Check the rpm idle speed. Verify it is 650rpms.
IMO, take the car to Infiniti and have it checked out. They know better than most independent shops unless the shop in question has a Consult II and the FSM. My guess is it's an exhaust leak. If you need a new cat, buy a used set from somehow on here or my350.com and have the Bank 2 cat installed. You should also verify that your car is outside of the emissions warranty. In some states, cats are required warrantied for 10 years/100K miles. Look in your owners manual for more info.
Old May 28, 2011 | 02:12 AM
poloavirex's Avatar
Dave thanks for all the tips i think there is a small leak at the cat when i drive i can hear something. I'm going thru Z1 Motor sports specialized in g35 & Z and i'm going to just get the High Flow cat both driver n pass for $400
check um out www.z1motorsport.com
Old May 28, 2011 | 10:31 AM
DaveB's Avatar
HFCs may or may not solve the problem. If it were me, I'd first figure out the source rather than throw $400 at it plus install and find out the problem was only a $10 gasket or some other problem not directly related to the cats.
HFCs aren't legal, but since you live in GA, all they do is complete a sniffer test and CEL check. Keep in mind that long term reliability of HFCs is a bit hit or miss and most don't last longer than 3 years before the cat bricks seperate and start making all sorts of racket.
Old May 28, 2011 | 12:23 PM
poloavirex's Avatar
Dave my goal also is to change the whole exhaust system from the header to the muffler but i was thinking that if i change the gaskets n change the cats also cause they are Rusted. might as well just do it all
Freeman186
Sep 6, 2023 10:07 AM
Crisci33
Jun 29, 2017 08:31 AM
teamghost
Aug 19, 2015 04:01 PM
Str8t G
Intake & Exhaust
Jun 13, 2008 12:43 PM
wootwoot123
Mar 20, 2008 12:04 PM
