i just need an ID on this part please
Old Jun 10, 2011 | 03:40 PM
VincenzG35's Avatar
just need to make sure this is what i believe to be the lower control arm can you guys please confirm
just to me accurate i need the name of that arm connected to the red shock/strut
heres why
Old Jun 10, 2011 | 04:45 PM
G35Papa's Avatar
That is the lower control arm and your inner bushing is shot just like mine
Old Jun 10, 2011 | 05:12 PM
VincenzG35's Avatar
Thanks so much chris u tha man where would I get the best price on ordering them
Old Jun 10, 2011 | 05:23 PM
G35Papa's Avatar
I'm not sure on the cheapest place to get them and I don't remember where I got mine from. I did go with Whiteline though like these
http://www.importpartspro.com/w52991g35.html
you're very welcome Vincenz
Old Jun 10, 2011 | 07:01 PM
VincenzG35's Avatar
I'm gonna just replace the whole arm every where I've talked to charges about the same in labor to press the bushings in and out also chris u can just call me vin
Old Jun 10, 2011 | 09:11 PM
VincenzG35's Avatar
Anyone have a part number
Old Jun 11, 2011 | 12:05 AM
G35Papa's Avatar
Wow...replace the whole arm? That sucks. I think those arms go for like $300 each. You don't have any friends that could help you get the arm off and then take it to a machine shop for the bushing swap?
I think these are the part numbers. Call your local dealer though to verify the part numbers
Passenger side
W0133-1765877
Drivers side
W0133-1722375
Good luck Vin
Old Jun 11, 2011 | 12:21 AM
VincenzG35's Avatar
Yea I got nobody to help lol the part from the dealer is 175 each so I'm gonna replace both because my passenger ones not that healthy looking either
Old Jun 13, 2011 | 08:46 AM
blklude98's Avatar
I changed all the lower and upper control arm bushings with the energy suspension bushing kit. It includes the compression rod bushing as well. Labor intensive but very worth it.
Vin you are welcome to try it out in my car if you wanna see how it rides with the energy suspension bushings.
Old Jun 13, 2011 | 12:45 PM
AARONHL's Avatar
What are the symptoms of a busted lower control arm bushing??
Old Jun 14, 2011 | 10:13 AM
blklude98's Avatar
I had clunking on slow bumps. Also, my alignment got messed up because the bushing was no longer there on the control arm so I got some inner tire wear. It was pretty obvious when I checked...Looked like this:
Literally popped out! And this was on both sides
Old Jun 14, 2011 | 12:25 PM
Mustang5L5's Avatar
Originally Posted by VincenzG35
Slightly off topic, but does anyone know why the compression rods have those "spurs" added to the rod? They don't connect to anything, but it's obvious they have a purpose as they look like they were added for a reason
Old Jun 14, 2011 | 12:38 PM
AARONHL's Avatar
I think it hits a part on the hub to prevent an excess of turning. It also helps when you need to loosen/or tighten nuts without the hub moving around.
Old Jun 14, 2011 | 12:40 PM
AARONHL's Avatar
I feel like these are going to do the same on my car, it's a common problem and especially now that I have about 130K on my G.
Old Jun 14, 2011 | 03:42 PM
VQEric's Avatar
^^ my inner bushings on both sides were shot just like this and I had no idea (no noise) until the tire shop noticed. Check your bushings! Also, I had been having some inner tire wear and new bushings (Whiteline) seem to have fixed the problem.
