Window regulator bolt
Old Jun 14, 2011 | 01:36 PM
albert3029's Avatar
I was trying to tighten up the rear passenger side window regulator bolts to get rid of that infamous creak the 04's have while driving. I managed to tighten one up, but broke the other one off! Just wondering if anyone can give me any advice on how to remove that broken bolt.
The creaking stopped alittle, but I hear it returning.
Old Jun 14, 2011 | 03:59 PM
Andyl's Avatar
The easy way is to just replace the $5 bolts but try a bolt extractor you can get them @ sears or homedepot
Old Jun 14, 2011 | 06:10 PM
albert3029's Avatar
Thanks, going to see if I purchase or borrow one from someone. The regulator it's position in a tight spot, will I have a hard time removing the broken bolt?
Old Jun 15, 2011 | 02:09 PM
Andyl's Avatar
Try to raise and lower the window see if it makes the bolt easier to get to sometime if you move it it will be easier to get at
Dallsinghjr1
Sep 17, 2023 11:25 AM
BradMD_96
Oct 6, 2015 09:31 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
