A bit of help guys...please and thank you.
Jun 23, 2011 | 02:06 PM
So I picked up the next to last part of my exhaust and I have done everything in the world to stop it from leaking at the flanges, seals for about a few days then, poof, back leaking again. Has anyone had beter luck with differrent gaskets, seals, gasket maker etc? I'm about to lose it and f***ing weld this pipe together , anyway thanks in adavnce.
- points to note,
2004 sedan g35 6mt
M2 HR Y pipe (3"in ---> nismo)
nismo ext. (3" ---> 350 middy 2.5")
350z middy
HKS Exhaust...
...beastmode...when it not leaking
- Tori
Reply 0
Jun 23, 2011 | 05:03 PM
Ooo... I hate exhaust extenders. If it was me, I'd remove the extender and have a muffler shop cut the flange and extend the pipe. It that where it's blowing out?
On a related note, it's refreshing to see such good manners in a thread topic title.
Reply 0
Jun 23, 2011 | 05:14 PM
Quote: Ooo... I hate exhaust extenders. If it was me, I'd remove the extender and have a muffler shop cut the flange and extend the pipe. It that where it's blowing out?
hmmmmmmmm, yeah that might be an idea, kind of iffy tho, I don't know where the car will be at in the next few years, I might want to sell the part later on if I move to back to stock etc...I was kind hoping that someone knew of a good sealent that may work. Cutting may have to be my last resource.
and thank you, I try to be very nice when requesting help.
Reply 0
Jun 23, 2011 | 05:45 PM
yeah im not going to lie bro, hes probably right it may be the extension. Have the shop do a custom pipe to make it work
Reply 0
Jun 23, 2011 | 05:53 PM
Quote: yeah im not going to lie bro, hes probably right it may be the extension. Have the shop do a custom pipe to make it work
Thanks for the help guys, looks like ill be setting an appointment. Yeah, it leaks at both ends of the extention Still if i have them make one, is ultra copper RTV to use on the flange from the Y to the middy?
Thanks
Reply 0
Jun 23, 2011 | 05:56 PM
im not too sure to be honest. If you're interested in selling the extension though lemme know
Reply 0
Jun 23, 2011 | 07:25 PM
Did you get new OEM gaskets?
I agree with the others though. Just get a custom pipe put on and then no more problems!
Reply 0
Jun 23, 2011 | 07:42 PM
I've used High temp Rtv with gaskets to seal up leaky connections like that.
I usually install,and then let it sit overnight before starting it up and testing it out
Reply 0
Jun 23, 2011 | 07:59 PM
...80 bucks for a flange and a weld around here O.O !!! F-that, following a suggestion, I'm going to pick up some new nismo gaskets and coat em in ultra copper, if that doesn't work, then I will pull the trigger on the weld. Thank you every one for all you imput, i do appreciate it.
***over 8 months to get a middy and cant keep it sealed ***
Reply 0
Jun 23, 2011 | 08:01 PM
yeah, new gaskets not nismo tho, had different ones but new and the same size.
Reply 0
Jun 23, 2011 | 10:21 PM
your not using the cheap paper gaskets are you?
you should try OEM nissan metal gaskets
Reply 0
Jun 24, 2011 | 10:04 AM
Quote: I'm going to pick up some new nismo gaskets and coat em in ultra copper
You are suffering from all the symptoms of warped flanges. Check those puppies with a straightedge before reassembly, and tighten the bolts a little bit at a time all the way around (not full torque on the first, then full torque on the second, etc).
Reply 0
Jun 24, 2011 | 07:15 PM
On the original seals did you sand out any left scraps that were left from the previous seals? When I got my shipment exhaust the old seals were stuck so Jairen and I sanded them down. I don't think mine leaks lol
Reply 0
Jun 28, 2011 | 05:48 PM
Wow leaking exhausts? That doesn't sound too fun...
Reply 0
