Receiver/dryer G35
Old Jun 24, 2011 | 10:37 AM
GBoy's Avatar
Receiver/dryer G35
When changing out the AC evaporator is it necessary to change out the above.
GBoy
Old Jun 24, 2011 | 12:16 PM
Mustang5L5's Avatar
The receiver/dryer is considered a disposible item. Anytime the A/C system is serviced, it's recommended it be replaced. In fact, most recommend it be changed out every 3 years for maximum efficiency of the system...but who the hell does that?
The dryer is like a sponge designed to soak up moisture in the system. Any moisture in an A/C system is death to the system, so that's why this part is so critical. Over time, moisture naturally finds it way in so this part begins to become saturated. If the system is open to atmosphere, it begins to soak in moisture like a sponge. When installing a new one, it's typically done as the final step and then left capped for as long as possible before connecting. Then, a GOOD vacuum should be pulled for 1 hour minimum.
In the past, i've gotten away with NOT replacing it by pulling a good vacuum for 24 hours or more. I just hook up my vacuum pump and walk away for a day. Water in a vacuum will boil off, but it takes time to make sure it's all evacuated properly. I usualy try to save the drier on friends cheap *** cars, or if i'm trying to do a cheap repair.
On an decent car, or a repair where you already have several hundred dollars invested, i wouldn't skip out on it.
Is a shop recommending it be replaces as a repair done to a leaky evap core?? If so...it's not BS, they are doing it right.
Old Jun 24, 2011 | 02:41 PM
jimNC's Avatar
Not sure this helps, but when I replaced my AC compressor/clutch with one from RockAuto, it was required to replace the receiver/dryer at the same time for warranty purposes.
Old Jun 24, 2011 | 02:44 PM
faiz23's Avatar
Shameless plug for Advance Auto Parts
https://g35driver.com/forums/g35-sed...arts-sale.html
Old Jun 25, 2011 | 07:34 AM
GBoy's Avatar
Thanks guys, I ordered an after market one, better safe than sorry. The evaporator has to be changed. Seems to me I read the whole dash comes out and even maybe the front seats..Sounds like a huge job for the home handy man..
GBoy
Old Aug 4, 2013 | 04:43 PM
tsevrens's Avatar
Hey there
I realize this post is really old but I'm hoping someone is able to see my response and help me out.
This will sound like a total newbie question but can anyone give me the location of the Receiver/dryer on my '06 Coupe? I have to replace the high pressure line and the receiver due to the aftermarket intake rubbing through the line.. sigh..
Problem is.. I've never done this work before and have no idea where the receiver is located. I'm going to have a shop do the evac on the system and then recharge it myself to save some coin.
Any help would be greatly appreciated!! There are no dumb questions right!!?
Thanks
Ty
Old Aug 4, 2013 | 04:59 PM
05_SkylineSedan's Avatar
20 Year Member
Service manuals for '06 coupe here:
http://www.nicoclub.com/FSM/G35/Coupe/2006_G35_Coupe/
"atc" is the AC section.
Old Aug 4, 2013 | 05:56 PM
tsevrens's Avatar
Right thank you! I have this already but I don't see where it refers to the replacement of the receiver.. that's why I posted the question.. Maybe I'm just looking in the wrong place in the document. It's about 160 pages long..
Thanks again!
Old Aug 4, 2013 | 05:57 PM
tsevrens's Avatar
Maybe it's called something else in the manual? I've seen it called accumulator, receiver, drier... so I'm not sure..
Old Aug 4, 2013 | 05:58 PM
faiz23's Avatar
I think receiver drier is in the engine bay around the front of the car like behind the grille but double check. Attached is PDF for ac lines and receiver drier.
http://www.sendspace.com/file/gckzrk
Attached Thumbnails Receiver/dryer G35-rd.jpg   Receiver/dryer G35-rd1.jpg
Old Aug 4, 2013 | 06:17 PM
tsevrens's Avatar
Thank you!! Yes I saw that part you circled and was just looking at it on my car thinking that it must be it. It's a lot larger than I was expecting actually so was looking for something small back by the firewall.
I really appreciate the help
Cheers
Ty
Old Aug 6, 2013 | 04:02 PM
Mustang5L5's Avatar
Correct, the circled part is the receiver drier.
Make sure after you replace it you have a shop pull a high vacuum on the system if you don't have the means to yourself
Old Aug 7, 2013 | 12:54 PM
tsevrens's Avatar
Thanks again for the help guys. I unfortunately don't have a compressor suited to evac the system properly so I'm going to have a shop do that and then recharge the system on my own.
Anything special I need to consider when I replace the receiver drier?
Old Aug 8, 2013 | 02:28 PM
Mustang5L5's Avatar
Don't do it on a humid day, and try to keep the new one exposed to atmosphere as short of a time as possible.
Old Aug 8, 2013 | 09:40 PM
markc's Avatar
Without a micron gauge, you can never pull a vacuum too long. I would suggest 1 hour minimum with a 6-8 cfm vac pump.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
