HELP! Overheating after radiator installation!
Old Jun 25, 2011 | 05:05 PM
2slickg35's Avatar
I just recently installed a Mishimoto radiator on a 2003 5AT sedan and after installing everything back and filling with coolant as well as using the bleeder valve, the car overheated. I'm lost and have no idea whats going on
Old Jun 25, 2011 | 05:30 PM
Tollboothwilley's Avatar
you still have air in the system. burp the system.
turn heat all the way to 90* and full blast the vents
let car idle until car is at normal operating temp
rev engine for 10 sec @ 2500 rpms
let idle for 10 sec then slowly open the bleeder valve...let the air hiss out and close it quickly as soon as coolant starts to drip out.
repeat this process until you no longer get air coming out.
I do this while driving a circle in a neighborhood. Do not let it overheat - stop and turn it off before issues. If you burp the valve you will find that just letting it sit for 3-5 min will build up more air even with the car off.
If you have a spill proof coolant funnel it is by far the easiest way to burp the system.
THIS>>>
http://www.google.com/products/catal...d=0CDQQ8wIwAw#
Old Jun 26, 2011 | 11:58 AM
DaveB's Avatar
Toll,
Do you have one of the spill-free funnels? I've heard nothing but good things about them. I really need to change my coolant soon and this seems like the ideal part to get air out of the system.
Old Jun 26, 2011 | 01:55 PM
ldg870's Avatar
Don't forget to remove the relief valve when filling. Fill very slowly.
Old Jun 27, 2011 | 12:48 AM
Originally Posted by DaveB
Toll,
Yes, I do
I have burped the system without one many many times but its much easier with the system. Very quick.
The method I explained above works great just takes 5-10 times of burping through the valve til the air sufficiently gone. You can really minimize how much air is in the system by slowly pouring the coolant in and squeezing the upper hose to cycle it around a little.
KevinnnVo
Oct 14, 2024 04:33 PM
junon
Jan 14, 2023 09:37 PM
saskicker32
Aug 11, 2015 02:12 PM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
