Brake help !
Old Jun 29, 2011 | 12:47 PM
007JD's Avatar
Brake help !
im having a hard time with my brakes...
first -
everytime i drive my car when i first start it up .. and reverse and or drive
i get a really loud loud squeal from the brakes and then later calms down
but usually the loudest when reversing out of drive way
second - after driving i see like this orange / brownish dust or stuff on my rotors.. and sometimes my rim is all dirty after...
i wanna get rid of that , cause i got some sevas chromes . waiting to be put on but dont want this problem messin them up .
soo any solution or idea . to help on the noise and dust problem
let me know thanks
Old Jun 29, 2011 | 12:58 PM
Bassman's Avatar
Let's see. The rotors are cast iron. You live in hot humid Miami. Can you say RUST. It's that orange / brown stuff that appears overnight on your discs. Japanese motorcycles use stainless steel to avoid this but cast iron works so much better.
Stay away from the beach to prevent rust. That salt air is a killer.
Old Jun 29, 2011 | 01:44 PM
Mustang5L5's Avatar
Brake noise combined with rust residue is a strong indicator you have worn down a set of pads and are now contacting backing plates to rotor.
Check your brakes...you are prob overdue for a brake job
Old Jun 29, 2011 | 02:58 PM
thescreensavers's Avatar
Mr.202?
The squeal first thing when backing out is normal
The rust is 100% normal, and goes away after a few brakings. Park in a garage if you dont want the rust. If I park mine outside, morning dew always makes my rotors have light orange/rust look
If the pads were due to change they would be squealing most of the time
Old Jun 29, 2011 | 03:12 PM
Mustang5L5's Avatar
I disagree..i don't think it's normal.
I live on a beach, can see the water out my windows and leave the car parked for days and the rotors don't rust. They only get light surface rust when it rains, but nothng that actually leaves dust on the wheels that is rust colored.
Only time i've seen heavy accumulation of rust-colored dust is when you have metal on metal braking. Having just experienced this with a seized caliper, i can also say that such a condition doesn't always grind or squeal all the time. In my situation, i had a minor squeal for a few mins when cold, and then it went away when warm...and found ZERO pad material on my rear pad on one side.
Just suggesting the OP give his brakes a visual inspection for pad wear to confirm.
Old Jun 29, 2011 | 08:58 PM
007JD's Avatar
i recently did my rears... the squeal doesnt come from the rear.. but there is dust and rust and all that orange and brown on the rear.
my mechanic said i might have to sand down or cut the front rotors which well help stop making that noise..l but the weird thing is .
when i did chnge the front pads / rotors it wasnt squealing for like a few weeks but now there squealing bad...
soo.. like stated ?
calipers can be bad ??
and other suggestion
and yes. my car is parked outside and is my dd.
and im not by the beach ..
idk and ideas or suggestion
thanks
Old Jun 29, 2011 | 09:00 PM
XDR-V35's Avatar
mine dose the same thing with my brembo setup.. exspecially if it rains or i wash the car, for like the first 20 feet until the surface rust is gone. running carbon ceramic pads with still over 1/2 pad left.
Old Jun 29, 2011 | 09:08 PM
Mustang5L5's Avatar
Worn pads aside.... Brake noise can be caused by inferior parts.
Are these oem? Or are they aftermarket parts?
Also, disassembling the caliper and using brake anti-squeal compound on the pad contact points can help eliminate squeal
Old Jun 29, 2011 | 11:09 PM
007JD's Avatar
rears r napa brake pads and rotors (cast iron ).. - the fronts are OEM pads n rotors
if anything imma just upgrade to the double piston calipers with bigger rotors
I have 04 model (single piston)
but more suggestions or solution would be greatly admire before i jump into this purchase
Old Jul 10, 2011 | 09:58 PM
007JD's Avatar
i took away the noise.... if anyone has a horrible squealing from there brakes..
and they have the single piston brakes in front .. just upgrade...
i upgraded to the double piston . no more squealing
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
