how to remove rust?
Old Jul 7, 2011 | 03:41 AM
SEDANFTW's Avatar
how to remove rust?
Is there a way to remove the rust before I go ahead and sand/paint/buff? or do I just go straight into sand/paint/buff? thanks!
Old Jul 7, 2011 | 04:20 AM
JRunSW20's Avatar
If its just surface rust which might just be it, go straight into sand, sand, primer, paint, then throw a few layers of clear coat. Some people get an angle grinder and go to bare metal but make sure you primer it right away
Old Jul 7, 2011 | 12:40 PM
artsVQ's Avatar
do what jrunSW20 said do it ASAP before it gets worse..... since its so small you might want to paint it with a paint touch up pen i think online or at a auto parts store you can buy the paint touch up pens
Old Jul 11, 2011 | 04:55 PM
kimi's Avatar
you can always pick up a fiberglass pen to remove the rust.
then go with the suggestions posted above.
Old Jul 11, 2011 | 05:23 PM
SEDANFTW's Avatar
what's a fiberglass pen?
Old Jul 12, 2011 | 07:03 AM
kimi's Avatar
Hello. Here is one on amazon:
Amazon Amazon
It is a pen with fiberglass bristles so you can remove the rust before applying primer, touch-up paint and clear coat.
Here is one with finer bristles:
Amazon Amazon
You can sand it like the other members recommended, but since you have such a small area, the fiberglass brush might work better for you.
Hope this helps.
Old Jul 12, 2011 | 07:51 PM
SEDANFTW's Avatar
thanks alot! will give it a try
Old Jul 12, 2011 | 08:19 PM
JOKER's Avatar
CLUB MODERATOR
park it in the desert in the middle of the sand storm.
it'l take care of the rust.
Old Jul 14, 2011 | 01:23 AM
Tremelo61's Avatar
SedanFTW, update the thread once you've tried this out?
I have an identical rust dot on my G...same spot too, and am curious if this would work for it. Never heard of a fiberglass pen till this post.
Old Jul 14, 2011 | 05:12 AM
SEDANFTW's Avatar
will do
Old Jul 14, 2011 | 03:13 PM
Badboy8813's Avatar
shouldn't this still be covered under the infiniti 7yr rust warranty?
Old Jul 14, 2011 | 03:53 PM
SEDANFTW's Avatar
nope it's not covered due to normal wear and tear
Old Jul 24, 2011 | 11:22 PM
SEDANFTW's Avatar
some updates, bought a fiberglass pen from amazon for about 3-4 bucks. works really well, better than sand paper imo since you can be more pinpoint the area more precisely. this is how it looks after.
Old Aug 1, 2011 | 11:39 PM
Lbui04's Avatar
Hey SEDANFTW, what did you do after you got the rust out? i just ordered a fibrebrush myself, my car has smaller rust spots. Im planning on using the touch up pen from the dealership afterwards. Was hoping you could update me on how your paint is now
Old Aug 1, 2011 | 11:46 PM
SEDANFTW's Avatar
after removing the rust, it was pretty much bare metal so I had to add a layer of primer then paint/clear after.
