HELP! Service Engine light after air filter change!
Old Jul 18, 2011 | 08:39 PM
Simm0nS777's Avatar
Edit: Im an idiot!! I must have not pushed in the plug that goes into the right side of the intake all the way! The VDC and SLIP light are now off but the SES is still on. Is it just a false SES light now and resetting it should be ok?
2006 G35X
So I did my first ever maintenance on my own to this car and figured Id start with the engine air filter. It seemed easy enough. I followed the DIY video exactly and thought I did it perfectly.
Now, when I start the car, it makes it about halfway through the normal start up sound, sounds like its about to shut off then finally finishes the second half of the start up sound and seems to run normally (I hope that makes sense). The service engine soon light comes on along with the VDC off light and the SLIP light.
I have no idea what could have went wrong. Everything seemed to go smoothly just like in the video.
Any help would be greatly appreciated!!!
Old Jul 19, 2011 | 01:57 PM
Andrew Lau's Avatar
I think the problem is the sensor. if it is, just try to fix it
Old Jul 19, 2011 | 02:02 PM
Deezflip's Avatar
MAF sensor, it's quite sensitive sometimes. Get some non-residue electronic contact cleaner from RadioShack. Spray the hect out of it, practically gushing/flushing it with the cleaner. Don't wipe it dry, don't touch it with your hands either.
The cleaner should dry fairly quick, then you should be good to go. You might want to a battery pull/reset also. In fact, you could do the battery/pull reset first and see if it clears it.
Old Jul 19, 2011 | 02:04 PM
Deezflip's Avatar
whoopsie, didn't see you edit on your post.
But yes, try the battery pull/reset. That might clear the SES. If the light comes back on, then try the MAF cleaning
Old Jul 19, 2011 | 03:06 PM
Simm0nS777's Avatar
Reset worked thanks!!!!
Old Jul 20, 2011 | 09:43 PM
WordUp's Avatar
and to add to this my service light went away after 2 or 3 days. I also got the light by not pluging in the plug during a filter change.
I do admit waiting for the service light to go away, is somewhat stressful.
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
justgotg35
Jul 19, 2015 12:33 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
