test pipe..
Old Jul 19, 2011 | 01:56 AM
ballsack's Avatar
test pipe..
i installed Megan resonated test pipes on my 06 sedan and its throwing a check light for cat not reaching threshold temperature.so i guessing the cat is not heating up enough, have anyone had this problem? i tried searching but did not find any answers. if anyone knows how to fix this problem please lmk thanks in advance.
Old Jul 19, 2011 | 02:05 AM
DrewDrew's Avatar
Am I reading this right?
Your test pipes replace your cats, thus throwing the code since you don't have cats anymore. You just have to live with the code. Certain companies make their test pipes so that they don't throw the code - I don't believe Megan is one of them.
Old Jul 19, 2011 | 02:07 AM
ballsack's Avatar
i under why test pipes will throw a code if the non fouler was not there... it would throw a code for o2 sensor... but im not having problems with an o2 sensor code. and only bank 1 is throwing this code not both.
Old Jul 19, 2011 | 08:39 PM
mkvl127's Avatar
ya thats wierd y only bank 1 in going...when i put in my test pipes both were going but then i got my uprev tune and no more code ..jus get tuned and ull b much happier..nothing but uprev
Old Jul 19, 2011 | 08:48 PM
sssmasss's Avatar
this is some good info. i didnt know test pipe could throw off a code..
Old Jul 19, 2011 | 08:53 PM
ballsack's Avatar
mkv127, i will definitely look in to the uprev. yes its weird only bank one is throwing a code (cat not reaching temperature). what kind of test pipes are you running on your car anyways?
Old Jul 20, 2011 | 12:23 AM
Dani01c's Avatar
curious question since no one has ever answered it to me, when you get test pipes, do you loose low end torque?
Old Jul 20, 2011 | 11:15 AM
ryanm8's Avatar
Yes, you will. Unless if you get ART pipes. Even with ART pipes though, you'll lose torque at very low RPM ( < 2000 or so)
Old Jul 21, 2011 | 11:12 AM
Dani01c's Avatar
thanks for the reply man, because my brother keeps on pushing me to buy some test pipes, because he put a test pipe on his SI and gave him 8whp and it was only one, but he argues that you dont lose anything, and if im not mistaking the more you open up exhaust on a N/A car the more torque you lose... now, do you lose any torque with high flow cats?
Old Jul 21, 2011 | 12:56 PM
ryanm8's Avatar
I guess I should clarify. You will gain torque overall, but lose it at low rpm. Over about 3k with regular test pipes you will still gain over stock cats. High flow cats will be pretty similar.
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
Visionnn
Oct 3, 2015 05:16 AM
