rear drivers side brake always hot, VDC and Slip sensor showing
Old Aug 15, 2011 | 05:52 AM
espgtr6969's Avatar
Brakes rear drivers side brake always hot, VDC and Slip sensor showing
I have 2004 sedan with 80k miles on it, recently the VDC and slip warning lights have come on and the drivers side rear brake is always very hot like the brake is sticky, the brake pad is eaten up very quickly, also when i try to but the parking brake on while in netural the car while roll. my main issue is the brake system eating through the pads so quickly and damaging the rotor on the one wheel, any help?
Old Aug 15, 2011 | 06:10 AM
VincenzG35's Avatar
Common problem not to expensive but more than wed like your caliper has froze the pistions no good replace the caliper and most likely the brake pads and you'll be fine
Old Aug 15, 2011 | 06:55 AM
espgtr6969's Avatar
i have ordered a new rear capil. and will let you if this works out, if anyone else has had a similar problem please feel free to chime in, thanks
Old Aug 15, 2011 | 08:09 AM
VincenzG35's Avatar
I've talked to a few people it seems to only happen to 03-04 sedans
Old Aug 15, 2011 | 08:34 AM
Mustang5L5's Avatar
Happened to my '06
needed new caliper because the slide pins seized. Inner pad only was pressing on the rotor. Reman caliper from rockauto only cost me $50..easy fix.
Old Aug 17, 2011 | 03:40 AM
espgtr6969's Avatar
UPDATE: I have replaced the caliper, the warning lights are now off, so far the brake temp seems to be cooler, and at the proper level I will update in a few days, however the parking brake issue still remains
Old Aug 17, 2011 | 03:44 AM
VincenzG35's Avatar
Glad the caliper info helped out...try pushing the parking break down with the car on and then releasing it after a minute or two
Old Aug 17, 2011 | 07:15 PM
Mustang5L5's Avatar
Pull the rotor and inspect the drum.
They can also be adjusted per the FSM
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/pb.pdf
Old Aug 19, 2011 | 07:56 PM
NFSP G35's Avatar
? = 2B || !2B
My caliper jammed. Rear Driver's side.
I took it apart and thoroughly cleaned/sanded it, reassembled, it was good for about 3-4 months and did it again. So I just replaced it. Hasn't been a problem since.
Old Aug 20, 2011 | 05:44 PM
GreenPenguin's Avatar
^+1. What is it about that rear driver side caliper?
Old Aug 20, 2011 | 10:31 PM
NFSP G35's Avatar
? = 2B || !2B
^IDK dude, but everyone I've heard talk about it, it's always the driver side!
Old Sep 1, 2011 | 04:20 PM
exiledtrinib0y's Avatar
i actually had it on the rear pass side but again 50 dollar fix was to just replace the caliper and pads 1 hr tops and about $70 dollars in parts good to go but i most def would look at the drum for the park break the shoe could be worn and can also be adjusted.
Old Sep 1, 2011 | 04:54 PM
Philly_G35's Avatar
I replaced my rear passenger side caliper at about 63,000 miles.
Ludz
Lights
Mar 28, 2016 02:06 AM
st33zygill
Jul 29, 2015 10:05 PM
teamghost
Jul 28, 2015 04:52 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
vstypicals
Jul 20, 2015 10:55 PM
