plasti-dip rims and grill black 06 g35x sedan?
Old Aug 18, 2011 | 01:11 PM
renegade3e's Avatar
thanks for the find but i was looking for black not bronze
Old Aug 18, 2011 | 01:13 PM
JaE35's Avatar
Moderator
G35 Sedan
lol i was showing you what you should do...don't keep the plasti as the standard coat, paint over it with a gloss black then a clear, did my oem grille and it looked fantastic
Old Aug 18, 2011 | 01:17 PM
renegade3e's Avatar
can you show me a pic?
Old Aug 18, 2011 | 01:23 PM
JaE35's Avatar
Moderator
G35 Sedan
Should give you an idea:
Originally Posted by stabadus
Decided to plasti dip/paint my stock 19s to glossy black. End result was somewhat decent; could have been better if I waiting more than 15 minutes between coats.
Steps I took:
1. Plasti Dipped the wheels (3 coats)
2. Sprayed gloss black gloss paint over plasti dip (2 coats)
3. Sprayed clear coat over paint (1 coat)
Let me know what you think.
Prep work (used index cards.. went to Walmart and found these.. 100 pack for $0.50):
PD 1st coat:
PD 2nd coat:
PD 3rd coat:
Paint 1st coat:
Paint 2nd coat:
How it would look on your car, all depends on what your car looks like obviously, i was just showing that done right...it can look good
Old Aug 18, 2011 | 01:46 PM
renegade3e's Avatar
that came out looking pretty nice, you can peel that off right? also any specific brand that i need to buy or just go in the store and get any random gloss black and clear
Old Aug 18, 2011 | 03:54 PM
DaveB's Avatar
I have a friend that's had a two C6 Z06s. Both cars had the rims plasti-dip. Both cars looked absolute killer and the rims flawless. The work is always in the prep.
Old Aug 18, 2011 | 04:55 PM
renegade3e's Avatar
did they sand the rims down or the coats? i want it to be reversible so i dont want to really mess with sand paper that much
Old Aug 18, 2011 | 05:32 PM
renegade3e's Avatar
ok so i screwed up my grill lol im not sure if i should sand it down or? i want it to be reversible though...it looks good from a distance but terrible up close
Old Aug 18, 2011 | 05:59 PM
4D05G35's Avatar
How many coats did you do? It's hard to tell, but it looks like you just need more coats to smooth it out a bit. Thin multiple coats not a few thick coats.
Sanding wont affect the outcome with plastidip (unless the part is gouged and knicked) because its textured, it bonds well and hids minor flaws.
Old Aug 18, 2011 | 06:01 PM
renegade3e's Avatar
i would say 5 coats (i finished a can), i started off with just a little plasti dip but then i used more with each coat...
Old Aug 18, 2011 | 06:21 PM
DaveB's Avatar
Nope. He just spend hours making the wheel surface completely clean and free of brake dust, grim, tar, and oil.
He coated them because the car is used for road course duty and the brake dust from the aftermarket brakes is pretty abrasive and corrosive.
Old Aug 18, 2011 | 06:41 PM
Mustang5L5's Avatar
If you are painting your grill black, you need to dp the headlights to to match
Old Aug 18, 2011 | 08:46 PM
JaE35's Avatar
Moderator
G35 Sedan
looks like you were spraying with the can too close, peel it off and try again lol
Old Aug 19, 2011 | 02:45 AM
Tunerz_Store's Avatar
I plasti dipped my front grille and it looks nothing like the one pictured above and this was months ago.
Old Aug 19, 2011 | 03:22 AM
  #30
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Here's a coupe with a gloss black grille
