z springs on g shocks ride quality ok?
Old Sep 28, 2011 | 08:49 PM
funnyscreenname's Avatar
i was going to try and find full z shocks and springs but, have a guy with just springs available from an 06 z. i know they'll lower my 05 sedan 1" all around but, from what i've read that's with the z shocks and springs. could i simply use the z springs on my shocks and it lower the car while maintaining good ride quality or do i need to hold out until i find someone with both shocks & springs from the z?
Old Sep 28, 2011 | 08:59 PM
olopez's Avatar
From what I've read you could do that & but it will wear out your shocks faster. What is the rush? Why not wait until you have the shocks & do the job once.
Old Sep 28, 2011 | 09:34 PM
brandon1978's Avatar
You can do it, but even if you have the sport shocks, you are asking them to dampen rear springs that are 33% stiffer. Whether you get new shocks or not, it will oversteer more with 06 (revised) Z springs. I had that setup and thought it rode roughly even with D-specs set to soft. That being said, if you are on a budget and went to reduce the wheel gap, it could be worth it. Also consider getting front z springs and rear G coupe non-revised springs. Then the spring rates will be the same as a sedan with sport suspension.
Old Sep 28, 2011 | 11:02 PM
itgogitrev's Avatar
I just did 350Z revised with new Tokico HPs. It's noticeably firmer, but HARDLY uncomfortable. Don't buy used shocks over 50K miles, they're most likely spent.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Rose M
Sep 30, 2015 05:31 AM
1Typhoon
Sep 25, 2015 08:45 PM
bigmike
Sep 17, 2015 01:58 PM
TheBay
Sep 3, 2015 03:27 PM
