Throttle body install
Old Oct 5, 2011 | 09:54 AM
EMG03's Avatar
Hello everyone,
I need to install a remanufactured throttle body in my 03 sedan because the original one was cleaned and got messed up. Ive done the throttle reset countless times and it idles fine all the time, it just randomly turns off whenever it wants. I wait 10 seconds for throttle to reset, turn it on and go on my merry way. My question is, when installing the remanufactured one can I do all the throttle learning procedures and thats it or do I have to take it to the dealer to sync it with a computer?
Any input will be greatly appreciated. Thanks in advance.
Old Oct 5, 2011 | 10:22 AM
PAIXAO's Avatar
You should just be able to do the relearn yourself.
Old Oct 5, 2011 | 11:25 AM
EMG03's Avatar
okay thank u, I just wanna be sure before I start the mission
Old Oct 5, 2011 | 11:28 AM
PAIXAO's Avatar
Make sure the negative battery cable is disconnected before you install the new TB
Old Oct 5, 2011 | 11:44 AM
EMG03's Avatar
will do, thanks man
Old Oct 21, 2011 | 05:30 PM
Mr. Samster's Avatar
i was wondering how did the reset go? I am about to do the same. But the dealer said that 9 out of 10 times i will need to do a consult to get it to work properly.
Old Oct 21, 2011 | 06:52 PM
Blue Dream's Avatar
I drove ttrank's car solo
I think the dealer's trying to get your money.^^ I have installed a number of throttle bodies on the DE motor and never had I had to take it to the dealer. Just follow the 3 or 4 procedures recommended to the letter and you should be good to go.
Old Oct 22, 2011 | 07:22 PM
I had just bought the throttle body from them so i was asking to see if i needed to do anything else besides the ECU reset, throttle position relearn and throttle valve relearn.
Old Oct 23, 2011 | 04:51 AM
Blue Dream's Avatar
You should be fine, no Consult needed.
Old Oct 23, 2011 | 12:06 PM
BuckeyeInMI's Avatar
One thing to remember is that the relearn means it has to, well, re-learn. This doesn't happen instantly, or even in one day, so expect a little inconsistent throttle response and idle speeds for a few days until it learns your style of driving.
Hasanbaloch
Feb 29, 2024 08:45 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
03sedang35
Aug 29, 2015 07:56 PM
