Broken coil pack bolt
Old Oct 29, 2011 | 07:40 PM
dan|el's Avatar
So I was doing my spark plugs today and was on the last one putting the bolt that holds the coil pack down and SNAP the bolt broke.. Not sure why this happened, followed the DIY from this forum and used the same torq settings on all the other bolts and noting else broke. It's pretty flush with the valve cover so there's no way to spin it out.. I've heard of the easy out tool but never use one before.. Any suggestions?
Old Oct 29, 2011 | 08:13 PM
redpearl99's Avatar
wow, how did you break the bolt and not break the plastic coil pack ?
Old Oct 29, 2011 | 08:22 PM
dan|el's Avatar
No clue.. The bolt just snapped, not sure if it was bad or what because all the other bolts tightened up just fine.
Old Oct 29, 2011 | 08:30 PM
bikinilust's Avatar
I've tried the easy out method w no luck....
Had to mig a tack on top of the bolt, then use a vise grip to turn it out.
If u do this, u have to do very quick tacks n cool it down fast, otherwise u might melt the vc.
Do this at your own risk. This was a last ditch resort for me, n I got lucky
Old Oct 30, 2011 | 05:19 AM
Blue Dream's Avatar
I drove ttrank's car solo
Best bet is to take it to a shop and let a professional do it.
Old Oct 30, 2011 | 12:40 PM
DaveB's Avatar
I wouldn't worry too much about it. It's more trouble than it worth if you can't get it out with the easy-out. The packs fit on there pretty snug. If anything, possibly consider cutting a peice of dense rubber and jamming it between the coil pack base and the fuel regulator assembly above to reduce the chances of the pack coming loose.......which is highly unlikely.
If you must remove it, the easiest and most effective way is to replace the valve cover.
Old Oct 30, 2011 | 01:10 PM
blazeplacid's Avatar
an ease out will take that bolt out
looks similar to this
http://www.brokentap.com/easy-outs.html
most parts stores have em.
I think a single one is like $10 and a set of different sizes is $40+
used one on an old radiator, thought It was done till I remembered the ease out I had
Old Nov 1, 2011 | 10:10 PM
dan|el's Avatar
Thanks for the input guys.. I ended up going to a local shop here and they were able to use an easy out type thing and they backed it right out. Didn't charge me either Glad that headache is over..
Old Sep 14, 2022 | 08:26 PM
BluTradition's Avatar
Infiniti G35 Coupe
Help
I'm very happy to hear it worked out for you.I did the same thing today. I've tried to unscrew the broken bolt myself but it's not happening.
What kind of shop was it you took your car too?
You also mention they did it free of charge, do you know why?
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
DRG35R
Jan 31, 2016 07:14 AM
KallDay86
Jan 8, 2016 12:42 AM
6spdGspot
Oct 5, 2015 01:55 PM
Claudiu
Sep 26, 2015 01:04 PM
