First Gen (03-06) G35 Sedan Tips/Tricks/Facts You May Not Know
Old Mar 16, 2015 | 10:41 AM
  #121
hamilton's Avatar
traction control
I installed a switch that turns off both traction control systems not just vdc like the button you already have, lift up the console around the gear shifter and the yaw sensor will be under where the passenger side cup holder would be, unplug it. It will say do not drop on it, then cut the orange wire and wire up a toggle switch. Now you can turn off all traction control and drift on dry pavement even if your all stock, I've done it. But unless you wire up a relay like I did you have to turn the car completely off then hit the switch the other way to turn it back on and when you turn the key back on and crank it your traction control will be on again. Also I always leave my key in the ignition with it cranked or not and lock it when I get out to go into the gas station and it will lock and unlock with the car cranked from the fob.
Old Mar 22, 2016 | 09:00 AM
  #122
Tacho Aguilera's Avatar
Reset ecu
Old Mar 22, 2016 | 09:05 AM
  #123
My g35
Old Jun 6, 2016 | 02:05 AM
  #124
Bobby88's Avatar
Do you have a lsd, welded or stock diff
Old Aug 4, 2017 | 11:58 PM
  #125
Lavrick Mulla's Avatar
How do I install billet grille inserts into the lower bumper??
Old Aug 13, 2017 | 08:31 PM
  #126
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
There are actually no option (or almost no option cars) out there. No Bose, no sunroof, whoever ordered my car ordered it stripped. No options other than the trunk mat and mud guards. And it was under $30k new.
Old Aug 14, 2017 | 06:09 AM
  #127
Blue Dream's Avatar
I drove ttrank's car solo
Old Aug 14, 2017 | 07:37 PM
  #128
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Just weird finding a "sport luxury" car so stripped. Had a '74 Z/28 with just the Z/28 option. No tach, no power windows, no a/c (someone added an aftermarket one) but that was back when people who wanted a faster car ordered them stripped so they would weigh less.
I'm guessing in the case of my G35, the original owner was just cheap.
Old Aug 21, 2017 | 07:42 PM
  #129
reno g35's Avatar
03 G35 a/c radio
my radio and a/c,heat is out.is there an ez fix or go to the dealer?
Old Aug 21, 2017 | 11:14 PM
  #130
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check the factory service manual, section ATC for troubleshooting steps (Google search the fsm, it's at the nicoclub site).
Old Aug 22, 2017 | 05:45 AM
  #131
Blue Dream's Avatar
The circuit board on the A/C controls went out. It's a common issue with our cars, it's also tied to the radio so they all crap out at the same time. You can replace the radio with another stock one which will probably eventually fail or replace the whole thing with a DD radio and an aftermarket faceplate with the A/C controls built in. Lots of info on that here: https://g35driver.com/forums/audio-v...urce-list.html
Old Jun 13, 2018 | 03:21 PM
  #132
John Franklin's Avatar
Holding the lock and unlock buttons on my '03 G35 doesn't toggle the chirp.
Old Jun 13, 2018 | 07:01 PM
  #133
Urbanengineer's Avatar
Hold them both longer, it should!
Old Apr 26, 2020 | 08:47 PM
  #134
EZChase's Avatar
G35X Premium Sedan
I have a 2006 g35x with the premium package and it has every other feature besides the reclining rear seats and I cant figure out why. It's bugging the hell outta me! Can anyone explain this?
Old Apr 26, 2020 | 10:51 PM
  #135
cleric670's Avatar
BANNED!!!
Replied to your same question in another thread.
