time for a clutch replacement!
I too need to replace my clutch ASAP (also flywheel I'm assuming). I am pretty set on the OE Exedy clutch given the price (~$230 on eBay), but I'm not sure which flywheel is cheapest/gives least chatter?
The Nismo seems appealing given the low noise, but I've heard that the Exedy NF04 is the exact same part? Is there any other flywheels, ACT or Exedy etc. that
Can anyone give any advice regarding these parts or other suggestions?
OE dual mass flywheel gives least chatter, but heavy (>28 lbs) and expensive.
From what I read Exedy is an OEM for Nissan, and Exedy NF04 weighs about the same as Nismo (~20 lbs). Another one from Southbend weighs between OE and Nismo, and claims gives minimum chatter, but I haven't read many people commenting on it. If you want to maintain OE driving characteristics then stay with flywheels close to OE weight.
Go to Tech section here and My350Z.com, do a search on flywheel and read up. I did and I still do that.
here's a hint: dont go thru the front door of the shop, rather go thur the garage door, find a worker (not the manager), offer him $20 under-the-table most likely he'll do it, after all a machine does the entire job
just my $0.02
edit: heres a youtube clip on how its done and looks like
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
eh, here's a slight better one that maybe answers a few questions (minus the horrid music and talking)
Wow so many choices. I was planning on the jwt and southbend combo . But now that there are others commenting on the exedy clutches and how it's close to $300, sounds even more tempting.
What about clutch and tranny fluid? Any recommendation for those? I read that ppl use Redline transmission fluid and call it a day. Not sure about the clutch fluid tho . I want something that Is better than oem. During traffic or hot days, my clutch fluids will boil over and the pedal would get stuck to the floor. I'd rather upgrade everything while its all off.
heres a little 101 on flywheels
http://www.aa1car.com/library/2003/bf100372.htm
I understand mechanically it can be done, given the flywheel has enough thickness. But I'd feel a lot more confident if the dampening parts on it can be replaced at the same time. The gripping surface on a dual-mass flywheel is not the only part that gets worn. I'd hate to open the tranny up for failed dampening component after perfect resurfacing job, after all it's not as easy as warped rotor which can be easily replaced. Just my .02.
Tranny fluid: I have Redline MT-85 in my tranny for about 6k miles now, and before it had factory Nissan fluid for about 30k miles. They're both good for my normal driving.
Clutch fluid: you can upgrade to DOT 4 fluid, which has higher boiling temp. Some said our clutch line is too close to the cats which gets clutch fluid boiled up, you might want to do some isolation while you're at it. Another reason for the clutch pedal getting stuck to the floor is failed slave cylinder, replacing it should be able to fix it.
I think a better comparison would be machining the rotor when replacing brake pads.
Update:
So, I went with the JWT Clutch kit with the Southbend flywheel. I was also thinking of saving some money by having it resurfaced but then thought....Hey, why not try something different. Even though its only 8lbs lighter, its still lighter.
Big props to Mike @ CZP for getting it to me in 2 DAYS! Thats fast for somthing coming from Arizona. Now, I will be getting the DOT4 clutch fluid just to be safe. Correct me if I'm wrong, but the clutch fluid is basically the Brake fluid, right?
I am really really excited to get this thing in! It just looks to be like a solid clutch! The fly is made in america (dont know if that makes any difference) but by the looks of it, I feel very confident on its reliability. And Mike assured me that they are a solid top-notch company.
I called R&D for a quote. I'm looking for another closer to home.
Update
well, my jwt clutch and southbend flywheel is finally in. The southbend flywheel seems about the same weight as the stock flywheel when I pick it up with two hands. Given thats not very accurate but eh, it is what it is. There seems to be little to no chatter at all.
Because of its weight, it sounds very close to stock. The engagement point is alot lower and engages much faster! Its gonna take some getting use to. It seems that this new setup "wants" you to release the clutch faster after shifting as opposed to the stock setup.
I'm getting alot of smoke from the bottom portion of the engine. I'm thinking its normal for all the grease to burn off, right? My mechanic also installed the ss clutch line, but he didn't save the original "heat shield"
that wraps around the stock clutch line. Is this going to be a problem?
![Biggthumpup](https://g35driver.com/forums/images/smilies/biggthumpup.gif)
![Confused2](https://g35driver.com/forums/images/smilies/confused2.gif)
#30
