Finally a G Owner!!!
Old Nov 21, 2011 | 09:36 PM
  #31
butkiss1's Avatar
1. Aem cold air
2.3/8" MD Plenum Spacer
3.Grounding Gear 10 wire set
4.Stillen ceramic headers
5.Stillen engine damp
6.Motordyne ART Pipes
7.Stillen Generation 2 Cat back/with custom Xpipe & Muffler (Low Rasp)
8.Blox Throttle body spacer
9.Osirus
10.Coolant control valve
11.Lower plenum ISO thermal Gasket
12.Rev limiter bumped from 6,750 to 7,600
13.Oil catch can
14.NGK Iridium
15.(5) ECU program modes *Anti-theft *Performance*
Valet*High fuel*Stock
16. Magna Flow Resonated Xpipe
17. Magna Flow Resonated dual in /dual out Muffler
18. 100 octane performance map
19. Ported and sandblasted lower plenum
20. Ported and sandblasted lower runners
DRIVETRAIN MODS.3.3 final drive swapped for 3.5 final drive (6MT)
DYNO NUMBERS 302.4WheelHP 273.8 Foot pounds
BTW please no negative comments on the dyno numbers.
Old Nov 21, 2011 | 10:32 PM
  #32
Songle6MT's Avatar
Originally Posted by butkiss1
1. Aem cold air
9.Osirus
13.Oil catch can
14.NGK Iridium
That is a lot of stuff! Your an auto? Those numbers don't seem bad at all to me. What these put out 230 ish give or take at the wheels 70whp is pretty good in my eyes
Old Nov 22, 2011 | 02:38 AM
  #33
dineth00i30's Avatar
Congrats. I'm truly jealous.
That's the G I wanted with all the options I wanted.
But, I wish you the best of luck with it. Keep us posted.
Old Nov 22, 2011 | 07:19 AM
  #34
TurTLe*'s Avatar
70whp gain is GREAT but if only he had a before/stock dyno. 300 is just a number now, kinda like saying our car stock is 260/280hp, just a number.
#9,12,15,18 are all options of the same mod AFAIK.
Many of us always regret not just jumping into FI but aside from the good $$$/+hp gains there might be a lot more headaches and downtime that we dont really want. Hence why NA works for most. Get good with the car before making it fast if you were to track it.
Old Nov 22, 2011 | 09:25 AM
  #35
rblue's Avatar
Yeah I plan to do a spacer and maybe an MREV2 but that would be about it. Then start saving for a blower ( most likely used )
What did you all do for your NA build?
Haha it did have an LS1 in it so it wasn't a total dog, but it could have been better that is for sure.
Maybe a bunch of us should email infiniti and tell them to make one
All I really wanna do is "like" the comment. I was thinking it may have an LS but I my knowledge isn't so great.
I came fairly close to just going with a GTO instead of the G35.
Old Nov 22, 2011 | 12:06 PM
  #36
Songle6MT's Avatar
That is very true, but there was still significant gains.
The headaches will always be there, whether the car is stock or FI. There will most likely be more headaches the more modded you are but that's part of owning a car
Ls motors are good, but driving one as a dd was not that fun. I would definitely own a firebird/gto down the road if it was strictly a play toy!
Old Nov 22, 2011 | 04:00 PM
  #37
TurTLe*'s Avatar
being stock plus small NA mods, I have no more headaches other then normal car owning stuff. Having owned a car with a add-on turbo, it was cake to get it running but more of headaches to get it running 100% right. Constant minor tweaks, tune, adjustments with a had a SR20DE-T. But the car always ran.
Old Nov 22, 2011 | 10:53 PM
  #38
Songle6MT's Avatar
Thinking more, There would be significantly less headaches with a near stock car, but they are still there in regards to trivial stuff.
Forced induction would present the opportunities for much, much bigger things to go wrong.
FI would just be soooo much fun!
invincible514
Sep 21, 2015 07:05 PM
TNRocker
Sep 21, 2015 08:36 AM
invincible514
V36 Engine, Exhaust, Drivetrain & FI
Sep 15, 2015 05:06 PM
mattdg35
Sep 14, 2015 11:28 AM
joeslates
Sep 11, 2015 11:19 PM
