Shift Knob not depressing the gate
Shift **** not depressing the gate
So I had uninstalled my AT shifter **** and my center panel so that I can remove my radio/CD changer to be sent off for repairs. Upon installing back my panel and shifter, I cannot depress the gate (via shifter **** button) thus not allowing me to shift into the other gear. But if I take off the **** from the shifter I can manually push down the gate and shift into gears without a problem? (Yes I am depressing the brake pedal when I am attempting this) Please help. Thanks!
Had the same thing happen. Took everything back apart & the screws that hold the plastic gate were just slightly loose. Lined everything back up, tightened the screws & it worked like butter.
