Debadged my IP G horrible mistake
Old Nov 30, 2011 | 12:15 AM
  #31
Chief.Crappin.Squirrel's Avatar
WTF?!?!...all you had to do was buff it out there was no reason to use touch up paint....GL fixing it especially since its pearl hopefully it doesnt take much
Old Nov 30, 2011 | 01:06 AM
  #32
TheDizzle's Avatar
This has to be a joke?!?! Well, if not, that is the correct paint code for IP. However your touch up paint should have come with two bottles. One has BC on it and the other has TC. BAse coat and Top coat, apply them accordingly... But I think you just need to get that off completely and try buffing first..
Old Nov 30, 2011 | 01:13 AM
  #33
FiveWunOh's Avatar
Someone got jipped!
Old Nov 30, 2011 | 01:33 AM
  #34
04WhiTe_G_Coupe's Avatar
How bad did it really look before the touch up paint cuz now its horrible?? I'm sure, before you put the touch up paint on that is, that it would have been an easy fix like everyone else is saying. Maybe a clay bar kit and some buffing/waxing would have evened it out a little. Not sure what to tell ya now. Good luck though.
Old Nov 30, 2011 | 06:21 AM
  #35
jeggo's Avatar
LOL! Sorry but instead of feeling bad for you I laughed when I saw what you did.
I srsly hope this is a joke
and where's the facepalm button here?
Old Nov 30, 2011 | 07:42 AM
  #36
NjMatteSedan's Avatar
Originally Posted by harley01
it looks like liquid paper.
Lmfao. It does!
Old Nov 30, 2011 | 07:57 AM
  #37
infinitig35's Avatar
Should have did a search on this website on how to debadged.
Old Nov 30, 2011 | 11:26 AM
  #38
Hotdawwgman's Avatar
God Damn the noobs!
Old Nov 30, 2011 | 11:32 AM
  #39
Wilg35j's Avatar
I bet it didnt look as bad as it looks now, all you had to do was buff the **** out..
Old Nov 30, 2011 | 11:38 AM
  #40
The X Factor's Avatar
Who did you get that paint from? That doesn't seem even remotely right. I'd get that new paint off asap, and go from there.
  #41
PAIXAO's Avatar
Cut the guy a little bit of slack. He's here for help. I think he already knows how badly it looks and how he messed up.
OP - You are going to have to have it wet sanded, polished and buffed out. You can do this yourself, but you are going to have to be very careful not to sand too much. Try some mineral spirits to get the touch up paint off.
Old Nov 30, 2011 | 11:47 AM
  #42
rvanderwerf's Avatar
even real QX1 touch up paint doesn't match all that great.. it's a tricky color for sure!
Old Nov 30, 2011 | 12:31 PM
  #43
05_SkylineSedan's Avatar
20 Year Member
Yeah, that's just the base coat of IP but don't bother with the top coat as it's not going to blend in. I say, to the body shop! If you're lucky they can just paint that little piece for you and feather it around the corner. Shouldn't cost too much. Good luck.
Old Nov 30, 2011 | 12:55 PM
  #44
bluedevils95's Avatar
So, are you going to fix it
Old Nov 30, 2011 | 03:38 PM
  #45
saywat?'s Avatar
lmao that was great! idk where people get these crazy ideas from. wheres they guy that sanded his trunk after removing his emblems?. OP jus get the bumper repainted should cost no more then $300
btw the trick with applying the tc of IP touchup paint is to do just ONE light coat and it should match pretty well. its when u apply thick coats and mutiple coats it turns out really dark
