Debadged my IP G horrible mistake
Old Nov 30, 2011 | 03:54 PM
  #46
DaveB's Avatar
You need to remove this new paint ASAP. The OEM paint has a clear coat which won't be affected by petroleum distillate. Clearly tape off the work area and lightly scuff the new paint. Apply a paint thinner type solvent and use some elbow grease. Keep scuffing the new paint to allow the solvent to penetrate the paint. Take care not to break through the new paint with the scuff pad. It will take a lot of time to break down and remove the old paint.
Once done, you'll likely need to do a lot buffing of the orginial clear coat. Ideally, this should be done with a high speed random orbital buffer and various stages of rubbing compound/polish to restore the original finish.
Old Nov 30, 2011 | 03:56 PM
  #47
saywat?'s Avatar
lol i like how people think OP is capable of doing anything to remove the paint without resulting in a football sized whole in the bumper. also its been a few days already. anything worth doing i doubt can be undone anyway even if by some luck this guy is capable of it at all lol
Old Nov 30, 2011 | 07:52 PM
  #48
iamtimshady's Avatar
^This.
With the mess on there now you need to take it to someone who knows what theyre doing. Watch them learn for next time.
Old Dec 1, 2011 | 01:38 AM
  #49
The X Factor's Avatar
I really just wanna know if that paint came from the dealer or not.
Old Dec 1, 2011 | 01:57 AM
  #50
thescreensavers's Avatar
Mr.202?
You guys are posting in a Troll Thread.
For real? Ok Go get some professional help, find a professional paint correction detailer.
Old Dec 1, 2011 | 07:38 AM
  #51
NjMatteSedan's Avatar
I think what happened was the OP figured once the touch up paint dried it would nagically change colors and match lol
Old Dec 2, 2011 | 06:21 PM
  #52
socialconflicts's Avatar
look at my debage.. clear come off when i did it.. idk why. but its fixed! for now lol.
Old Dec 2, 2011 | 08:06 PM
  #53
04WhiTe_G_Coupe's Avatar
Lol...hell of a job.
Old Dec 2, 2011 | 08:22 PM
  #54
bluedevils95's Avatar
That is the best way to fix a car!!! LOL!
Old Dec 2, 2011 | 09:44 PM
  #55
68_GT's Avatar
is that touch up paint sprayed on or brushed on ?
touch up paint is good for small nicks and dings not large areas that mess has to look much worse that it could have before.
like others said if you did that I don't think you should put any grit sandpaper on your car. If you do anyway please make it 2,500 grit on a sanding block and run water from a water hose over the area while doing it with the good paint taped off.
good luck
Old Dec 3, 2011 | 03:55 AM
  #56
no joke. took me seconds to fix it up! lol. but in all seriousness.. it doesnt look that bad
now if i went to home depot and bought blue paint and coated it over my car.. i dont think that would work out that well... i may be in the same boat as the OP...
Old Dec 3, 2011 | 07:56 PM
  #57
xxxxxxxxxx's Avatar
lmfaoo sorry but wtf were you thinking guy
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Kelvin Style006
May 23, 2016 03:47 AM
n2fooz
Sep 4, 2015 07:46 PM
