VDC light on after control arm replacement
Old Dec 4, 2011 | 06:57 PM
od2681's Avatar
My alignment had been horribly off since my steering wheel was about 20degrees off center to the right. Turned out it was the drivers side lower control arm bushing. I replaced the control arm today and now the wheel is off center to the left. After driving for about 10 mins, the VDC light comes on and "slip" light comes on. Can it be that my alignment is so horribly off that the front wheels are fighting for control. It tries to pull either left or right hard when you make turns now. I will try to get an alignment done tomorrow and see what happens. Any suggestions?
Old Dec 4, 2011 | 08:26 PM
4D05G35's Avatar
Yes it is most likely your alingment.
Old Dec 4, 2011 | 10:18 PM
od2681's Avatar
Cool thanks. i will get it done tomorrow and will post with hopefully positive results
Old Dec 6, 2011 | 04:27 PM
infinitidude's Avatar
the light is caused from the steering angle sensor being off center,once the alignment is completed,the dealership(technician) is supposed to use Consult to recalibrate the steering angle sensor. The alignment alone will not make the light go off once it is on. Hope this helps bro.
Old Dec 6, 2011 | 09:27 PM
Michael Joneser's Avatar
My first thought was wheel speed sensor unplugged. Good info on the steering angle sensor.
Old Dec 8, 2011 | 10:06 PM
no problem man, keep me posted and let me know the result of what you found
Old Dec 9, 2011 | 04:08 PM
Infinitidude your car is really clean, what rims are those?
rezendvous420
May 31, 2020 01:26 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
Jussaku
Jul 29, 2015 11:45 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
itschuckster
Jul 25, 2015 08:07 AM
