Uh..how do you turn the heater on?
Old Dec 28, 2004 | 07:10 PM
skeleton_cru's Avatar
Sedan
Originally Posted by mikeee2
Quick question. When I start the engine, the outside temperature is never accurate. It's been cold in NY so the outside temperature has been in the 20's. Everytime I start the car, it saids outside temperature is like 60+, then as the car warms up and drive it for like 5 mins, then it shows the accurate temperature. Do you guys have this problem?
That is normal. It takes a few minutes to adjust.
Old Dec 29, 2004 | 12:33 AM
Jp1's Avatar
Jp1
Smile temp problem
The temp sensor needs time to get good info. If you leave the car in your garage it will take some driving time to get an accurate ambient temp reading.
Old Dec 29, 2004 | 03:57 AM
xswl0931's Avatar
The temp not being accurate is normal, although annoying.
Old Dec 29, 2004 | 09:01 AM
PotomacG's Avatar
I was always under the impression that running the AC when it's cold outside will ruin the compressor. Apparently, with the G, this is not the case. The AC light coming on is a normal part of the auto climate control function. As mentioned several times earlier, just press "Auto", set the temp and forget it. If the temp gets comfortable and the fan is still blowing a little too vigorously, just dial down the temp a few degrees. The climate control system does a great job once you learn to just leave it the hell alone
Old Dec 29, 2004 | 10:00 AM
RBull's Avatar
Rated M
A/C damage
Running the A/C when it is cold out will not damage the compressor. In fact not running the compressor for a longer period (like for several months over the winter) will damage the compressor,letting corrosion set in and drying out seals. Most newer vehicles including the G will cycle the A/C automatically almost no matter what temperature when in defrost mode. This is a safety precaution for the A/C compressor so it gets some use and is also more effective in clearing moisture from the interior windows.
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
master111
Sep 25, 2015 08:32 PM
