PCV Torque
Old Jan 16, 2012 | 10:33 PM
G35CO's Avatar
PCV Torque
What's the torgue for 2003 G35 sedan PCV? Thx
Old Jan 17, 2012 | 12:40 AM
TunerMax's Avatar
G35
nicoclub.com/fsm
Old Jan 17, 2012 | 10:43 AM
G35CO's Avatar
Originally Posted by TunerMax
nicoclub.com/fsm
Didn't find it in the fsm
Old Jan 17, 2012 | 05:26 PM
SuperTrooper699's Avatar
isn't it 260?
Old Jan 17, 2012 | 08:06 PM
TunerMax's Avatar
G35
2 minutes.... Here you go:
Old Jan 17, 2012 | 10:45 PM
G35CO's Avatar
Thank you! How did you find it?
26 in-lb, my torque wrench don't go that low. I guess I'll put take it easy with the wrench.
Old Jan 18, 2012 | 12:16 AM
AARONHL's Avatar
Just take a guess, you wanna snug it up and then slightly turn it. It's a 10 or 12mm and doesn't hold anything together...not that important to have the exact torque.
Old Jan 18, 2012 | 10:13 AM
TunerMax's Avatar
G35
Most important not to overtighten. Use a new Oring and put some dielectric grease/white grease/engine oil on the oring prior to installation.
Tighten it by hand then a minor snug with a wrench will be more than enough, no more than 1/8" of a turn after fingertight.
And I found it by looking in the FSM
Rocker-cover portion.
You could've also went to index and found PCV, then went to the corresponding section. If you know the exact Nissan part name this is an easy way to find something if you're unsure of what section it's in.
Old Jan 18, 2012 | 11:11 AM
G35CO's Avatar
I looked in the fsm but the index didn't take me to that section. Thanks again for your help!
Old Jan 18, 2012 | 05:29 PM
TunerMax's Avatar
G35
Nooo problem man
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
NailBomb
Oct 28, 2015 07:53 AM
n2fooz
Sep 4, 2015 07:46 PM
yosip1115
Aug 26, 2015 10:46 AM
lemmy999
Jul 25, 2015 12:13 PM
